I-015: DIY- Video on Nav for free - UPDATED 7/14/10
Old 07-14-2010, 05:07 PM
bjohnston115's Avatar
Here is an update to my original thread.
Ok enough talking, heres some pics ...
This is the connector that goes to the rearview camera. THis is located on the trunk lid under the carpeting. It snaps off easily.
Ok here we have the video on the screen. I hooked a spare camera up to the connector in the trunk and i got the picture on the screen. The only catch was that i could not make the video appear when the car was not in reverse. Problem solved below...
This is the diagram on the connector pictured above.
Heres the meat of this operation. This shows how the nav unit knows the car is in reverse and to turn on the camera. Up in the top left you see the backup switch which is located under the hood on the top of the transmission. Next in the bottom right you see the wire that plugs into the nav unit. This light blue wire on connector A swithces the unit into reverse mode.
here you can see connector A. Very easy to get to.
And the connector A diagram. You see the backup light is the LT bLue wire on pin 5.
My next step from here is to map out the back of the nav unit and find the video outputs there so we can get video on the screen without useing the backup camera plug.
Any questions class???? Haha im so pumped about this.
Old 07-14-2010, 05:16 PM
Jonnie5's Avatar
*applause*
awesome job man, loving the progress, can't wait to connect a dvd player to the thing lol
Old 07-14-2010, 05:54 PM
ill have that soon. luckily i have a single din dvd player and it should fit right on the little shelf in the glove box.
Old 07-14-2010, 07:22 PM
SeeYou2Crew #2
ed_423's Avatar
awesome! too bad i dont have the tech package
Old 07-14-2010, 07:29 PM
civichbdx's Avatar
Sweet i can't wait you rock
Old 08-04-2010, 08:53 AM
mdx_1976's Avatar
Does this also work on the 08 MDX?
Old 08-11-2010, 07:59 AM
Mjakaz09TL's Avatar
I have been looking into this for some time now for the 3g TL. I have all wiring schematics since i did the 07 navi conversion i have an 06 TL. I have a switch connected to my back up cam so i can flip it on anytime i want. I also have another back up cam that i was going to mount on front of the car to flip on anytime as well. So since we all know that achieving video to add a DVD player is fairly simple now all we need to do is figure out how to turn it on... that is where i am stumped! Its easy to go thru the back up cam for an on/off switch but dont think it would work the same for dvd player...
So any ideas? Maybe a relay and or diode may solve this?
Hmm, just had a thot.. what IF you took the back up wire, cut it and ran one end to a SPDT on off switch "center" position, then connect a wire to say the "up" position and run it back to where u cut the backup wire so this way when u have the switch in up it will allow the back up cam to work normally. Then run a wire from the "bottom" position to the DVD player video?? In theory id say this would allow the dvd players video to display on the screen...
Old 08-11-2010, 08:41 AM
Mjakaz09TL's Avatar
Correction... im thinking the "bottom" position you'd run the wire from it to the 12v on the dvd player and run the video out to the video in of the back up cam wire. Since if im not mistaken the reverse switch wire is supplying the voltage that turns the camera on. Again in THEORY u supply power to the back up cam u get the display on the screen, well when u flip the switch ull now be supplying power to the dvd player and once it turns on id assume anything playing thru it would show up on the screen? Im guessing since i dont have the schematic in front of me atm..
and damn... thinkin even more about it, the switch idea should work however the car still wouldnt know it was in reverse.. haha this would only work if the car was actually put into reverse. SO we need to add power to this with a diode similar to how the on off for the back up cam is done. Hmm how to do this??
Old 08-11-2010, 10:07 AM
hjahmad's Avatar
Im pretty good with video connections and stuff. but i dont want to take apart my dash in a brand new car. id love to see the schematics on this.
i also want to put a separate switch in for the backup camera so it can be used with out being in reverse. can you pm me on how you did that?
Old 08-11-2010, 10:10 AM
hjahmad's Avatar
where can i find these pdfs?
Old 08-11-2010, 11:48 AM
hjahmad's Avatar
http://www.navtool.com/acuratsx2.aspx
Old 08-11-2010, 12:48 PM
yeah the nav tool is cool but it is 350. I lease my car so im not going to spend 350 on that unit. If i bought my car i definately would have gotten the navtool
Old 08-11-2010, 01:11 PM
Mjakaz09TL's Avatar
So any updates on this?
Old 08-15-2010, 09:56 PM
Exit117TSX's Avatar
I second that, what's the deal?
Old 08-23-2010, 06:53 AM
Mjakaz09TL's Avatar
Lalala
Old 08-25-2010, 01:23 PM
hjahmad's Avatar
so i gave this a shot but failed
i was stupid and tried jumping without having the connector A plugged in.
also, the colors didnt seem to match with what you have unless i was just not looking at it right.
it looked like the light blue wire on mine was in port 1, but the diagram shows 5.
do i go with light blue, or whatever is in port 5.
also, with what port number do you jump it with? gnd?
what tools did you use to get to the wire? i bought 14-18 gauge taps but they are too big.
Old 09-07-2010, 03:46 AM
lopez205tx's Avatar
he used the plug that hooks straight to the rear camera,
Old 09-07-2010, 04:02 AM
lopez205tx's Avatar
i think their is a way to splice into the video input, im thinking that its one of this wires in this unit
maybe you can get the pin out for this, i know that this hooks to the navi..
Old 09-07-2010, 08:48 AM
Mjakaz09TL's Avatar
Eh, navtool, doms unit all a FAT waste of money. I took the time to handle this over the wknd and did it for free.. so simple it makes me sick people charge over $200 for a module when u can do yourself for a few bucks unless you alrdy have a spare rca cable laying around.
Then again i have a 3g TL but as long as u know what wires are what ur good.
Old 09-08-2010, 09:32 AM
is that unit behind the rear seat on the passanger side? If so, that is the xm radio module.
Old 09-12-2010, 03:40 AM
lopez205tx's Avatar
yes it is, Does any one know how to pop open the LCD panel?
Old 04-28-2011, 02:16 AM
Jonnie5's Avatar
anybody get this working?? sorry to bump an old thread, but i wanna plug a dvd player in!
Old 04-28-2011, 06:59 AM
Mjakaz09TL's Avatar
Yeah i did LONG time ago, tho i had a TL any car with a back up cam should be able to display video for a few bucks. WISH i had the time to make my own unit id sell it for half of what the others were and still make a huge profit.
Old 04-28-2011, 09:15 AM
Op is too busy to care
KillerG's Avatar
the TL has so much documented wisdom for it! i hope the 2g gets as much stuff as it does one day
Old 04-28-2011, 10:40 AM
hjahmad's Avatar
i agree
i tried the mod, had to quit cause i wasnt really sure of a lot of things
i would like to see more detail of the whole process.
show which wires, not just tell. cause my colors just dont seem to match what he is showing.
ill probably give it another shot sometime this summer, once it finally stops raining
Old 10-26-2011, 05:48 PM
methodDK's Avatar
Anything new on this subject? Trying to get external video through camera plug to no avail.
Old 12-14-2012, 12:52 PM
hjahmad's Avatar
Any thing new on this? I have a few questions as somethings are not as clear to me.
I am looking to connect a raspberry pi to the car and have it display onto the nav screen.
agupta3224
05-23-2017 08:30 AM
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
Quick Reply: I-015: DIY- Video on Nav for free - UPDATED 7/14/10
