DRL & fog bulb sizes
What are the bulb sizes for drl/ high beam and fogs. Looking at nokya bulbs to make drl whiter and yellow fogs. Anyone recommend which ones are clean bright white and yellow and is plug n play just like stock
7# werC 2uoYeeS
To be honest, if you're looking for a pure white color for the DRL's, the only way you'll get that is if you use LED DRL bulbs. And you're going to need a resistor for that to get rid of the DRL Error message on your dash. Any other bulb you get, whether it be Arctic White (the bulb I have) won't give you that pure white color. All other DRL bulbs (high beam bulb since they're the same thing) will still give you that yellow-ish hue.
