Both Front Passenger Window and Sunroof will not respond to ANY controls.
Old 02-22-2017, 01:16 PM
2011TSXer's Avatar
This above issue appeared at the same time. The Front Driver's Window also has some issues when I try to send auto up/auto down.
Old 02-22-2017, 01:17 PM
Received 8,693 Likes on 6,707 Posts
Have you checked your fuses?
Also what car do you have? Your user name and the subforum in which you've posted does not match.
Old 02-22-2017, 01:21 PM
2011TSXer's Avatar
thoiboi,
Sorry for the confusion. I'm a Newbie. I have a 2011 TSX 4 Cyl w/Tech Package. I have not done any trouble shooting as of yet. Just trying to gather some info first.
Old 02-22-2017, 01:22 PM
Gotcha,
we'll have it moved to the TSX forum. But it's going to be one of your fuses if i had to venture a guess. Check them all
2011TSXer (02-22-2017)
Old 02-22-2017, 01:29 PM
projektvertx's Avatar
Moved to the TSX subforum. Thanks for the alert and hopefully the TSX members have a fix for you
oo7spy (02-22-2017)
Old 02-26-2017, 06:23 PM
Atron483's Avatar
Hello, this is my first post! I just had a similar issue both front windows not working rears were fine. Didn't try the sun roof.. Anyways I was working on the car and the battery had run down to 10 volts. As soon as I put a charger on the windows all worked.
See if your battery is dying, or try them with the car running, if you haven't already.
TSX69
ZDX
70
10-10-2013 08:20 AM
rfrys
04-26-2006 10:57 AM
vp911
07-07-2005 03:52 AM
gavriil
11-21-2003 10:17 AM
Quick Reply: Both Front Passenger Window and Sunroof will not respond to ANY controls.
