blue tooth help
SeeYou2Crew #2
blue tooth help
i was trying to call someone, but i did not save their contacts in the bluetooth system, so i had to look up his name and say his number. but instead of doing that i tired to just click call on my phone, but it does not transfer to my bluetooth speakers. is it suppsoe to be liek this? or a way i can fix. i have a base model.
hit call then hit speaker phone, then once " speaker phone" disappears off your phone hit speaker phone again, it will transfer to the blue tooth. Unfortunately unlike toyota Acura hasn't caught up with the one touch call ffeature from the phone.
so turn speakerphone on once phone call is initiated then turn it off, will transfer
Registered but harmless
Received 1,102 Likes
1) Call on the phone, then say "Transfer" using the HFL button-- that will transfer the call from the phone to the HFL.
2) Call on the phone, end the call as soon as it dials, then use the HFL and say "Redial"-- the HFL will redial the last call.
That's all in the owner's manual in the HFL section.
I recently took over a 2006 TSX and am trying to set up the system blue tooth to make outgoing calls.
I have a Motorola Razr and have set it up with blue tooth to receive in-coming calls, no problems.
However, I have not been successful at making outgoing calls (only by accident) via blue tooth.
1. Any tips on how to set up outgoing calls?
2. For numbers not stored in the car (i think there is a capacity), is there a way where I can dial from my cell phone and simply press a buttom in the car to transfer the call over to blue tooth?
Thanks for your time.
CLOSED: 3G Acura TL Model Car(Blue)
bluetl04
08-16-2016 02:49 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
