2013 Tsx radio no working/powering on
Old 09-24-2015, 08:33 PM
jdmaszfcuk's Avatar
HELP a-zine !! My radio just went blank all of a sudden not working not coming on I checked all fuses n took the battery terminals off
Old 09-24-2015, 08:35 PM
Received 8,691 Likes on 6,705 Posts
Any other symptoms or just radio? Check lights all around.
Also check fuses again.
Old 09-24-2015, 09:02 PM
jdmaszfcuk's Avatar
Just the radio check them all twice ...
Old 09-24-2015, 10:11 PM
cu2wagon's Avatar
Received 7,772 Likes on 5,045 Posts
Base model or Tech Package?
Old 09-24-2015, 10:29 PM
Bchester6's Avatar
Take it in to dealer. gotta be under warranty still...
Old 09-25-2015, 05:52 AM
jdmaszfcuk's Avatar
I was going to do that but I have a system in the car but it was working fine before , I hope they don't say the system did something cause for sure I know it didnt
Old 09-25-2015, 05:53 AM
jdmaszfcuk's Avatar
Base model
Old 09-25-2015, 09:51 AM
icu2tsx's Avatar
Where is your power amp wire source coming from (blue)? I assume you are using a LOC.
I would double check on fuse under the the dash.
Old 09-25-2015, 10:18 AM
VTEC just kicked in, yo!
xtcnrice's Avatar
Received 1,112 Likes on 876 Posts
I have tech, happened to me once but all was fine on next startup of the car
Old 09-26-2015, 09:36 AM
Bchester6's Avatar
Check fuse on back of HU for sure. If you have to replace because it's blown then I would consider a bad ground connection somewhere in your wiring. I've only seen it once in my lifetime but if it keeps happening then it could possibly be a bad HU. I have also had to replace the fuse under dash on passenger side as well due to over stressing at high volumes. Heehee.
Old 09-29-2015, 06:19 PM
jdmaszfcuk's Avatar
I checked all fuses and there's no fuse behind the head unit
Old 10-02-2015, 08:07 AM
Bchester6's Avatar
No fuse behind the headunit? On the backside of unit?.... what brand and model is it?
Old 10-13-2015, 11:45 AM
jdmaszfcuk's Avatar
It's the base model "premium sound system"
Old 10-14-2015, 09:45 AM
Bchester6's Avatar
I'm sorry I thought you said you had a system and that's why you couldn't take it to the dealer. I'm confused...
Old 10-16-2015, 05:01 AM
TSXV6Guy's Avatar
what "system" do you have, and does it have anything to do with the radio? If yes, then start by checking the wiring and all interconnections.
Old 10-16-2015, 07:12 AM
cu2wagon's Avatar
HFS, it's like pulling teeth to get jdmasfuck to actually prove information.
How about this: OP, start over. Write a reply and include the basics of a good sentence when stating your problem:
-what
-when
-why
-how
This isn't a telegraph; you're not being charged by the word. Don't be afraid to use many of them to clearly define what you're saying or showing.
Pretend like we know nothing about you or your problem and you want to sufficiently convey what you know to others so they can help you.
Old 10-19-2015, 12:31 AM
Bchester6's Avatar
Let me guess, the "system" is a LOC connected to an amp and sub? Shouldn't short out the stereo if that's the case.
Puma Jim
20
10-20-2016 11:59 AM
SinCityTLX
20
10-19-2015 11:23 AM
chiu0nthls
3G MDX (2014-2020)
09-28-2015 03:46 AM
Matthew Purpura
09-25-2015 06:10 PM
95oRANGEcRUSH
09-25-2015 12:50 PM
Quick Reply: 2013 Tsx radio no working/powering on
