2010 tsx tech with remote start question
Old May 22, 2010 | 12:05 AM
baltimorecaesar's Avatar
Just wondering if there is any way to get the windows to roll up with the key fob, and also wanted to know if there is a way to keep the engine running when started with the remote start and unlock the doors.
Old May 22, 2010 | 02:38 AM
09TSXTech's Avatar
Congrats on your purchase and welcome to the forum.
You can roll down the windows and moonroof simply by holding the unlock button on the keyfob, however, to close the windows and moonroof from the outside, you need to insert the key into the driver's door, turn once to lock and turn again and hold to close all the windows.
I don't know much about the remote starter as I drive a 6MT model. My understanding is that the engine will stop once you unlock the car, it should also stop if you move the shift lever out of the P position; unlock or open the doors or the trunk lid; open the hood; insert the key in the ignition switch or press the brake pedal.
Old May 22, 2010 | 09:01 PM
kapana7's Avatar
8th Gear
I know the engine will keep running if you unlock the doors with the remote starter, I haven't tried to opened them with key yet
Old May 23, 2010 | 01:22 AM
09TSXTech's Avatar
Are you sure you don't have an aftermarket remote starter?
Acura remote starter transmitter only has three buttons (Command / Start/ Stop), no open or close buttons to lock or unlock doors.
Old May 24, 2010 | 03:46 PM
just to clarify, you cannot unlock the doors with the standard key fob, unless you first stop the engine with the remote start.
Old May 24, 2010 | 05:10 PM
kapana7's Avatar
8th Gear
I didn't know Acura had their own remote stater, mine is aftermarket
jriv7
May 8, 2020 05:50 PM
Rocktman1
Oct 31, 2015 02:33 PM
kixo
Sep 5, 2015 08:54 PM
jordanboi
Sep 5, 2015 01:33 AM
datadr
Sep 2, 2015 06:46 PM
