2009 tsx rear deck speaker size? they do not look like 6x9 as posted in other threads
Has anyone installed 6x9s in the rear deck? I have already purchased the 6x9, will i need to return them?
I also read that you can pop the coves on the rear deck speakers off for access and its only the sub that would require rear deck removal to gain access. does this sound right?
CU2 TSXClass
CU2 TSXClass
u can try fitting 6'5 on the doors if u do some type of modifications soo the windows can come down all the way this is how my passengers door was looking like when i replaced the 6' speakers
I replaced my rear door speakers with 6.5" infinity reference speakers. I did not need a spacer and just drilled new holes with sheet metal screws. mounting depth was 2" on the infinity's. I was planning on switching out all stock speakers but now I'm just gonna return the rest and keep the stock front and deck speakers. I will be swapping the stock sub with an 8 inch infinity and adding an amp to it. With the bass turned down the stock system is plenty loud and clear, the sub will fill in the lows.
Also i noticed the rear door speakers seemed to have been water damaged. I suspect window tinting is to blame for all those with blown factory speakers.
Because most Dominicans/Puerto Ricans put Beymas in their cars. I'm Dominican as well. Which Beymas did you go with and how do they sound?
I just picked up two 6" and one 8" audiopipes for the rear deck and just installed my 13.5" JL W7 w/ the JL 1000/1.
Its not specifically made for IB but they say you can use it in IB configuration, it will just have less power handling capacity. I figure with a aftermarket amp its gonna sound better then the stock sub. I read somewhere someone replaced just the factory sub with this and sounded better even with stock amp. It wasn't a tsx tho. I forget what kind of car.
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
