Wow I hate my Blade Key Fob on the TSX!!
3 Attachment(s)
There are some complaints but not that many in my TSX.
However there are issues that really that we shouldn't be experiencing especially in premium/luxury segment of the car... It's a minor issue I know but if there is no push start engine/keyfob then get the key fob to be solid in return... but no... I saw many forums regarding the cheap plastic metallic thing on the button that peels off so easily. what is this? anyways, if they don't give us feature that should be standard in 30k segment cars, at least they should have got the quality of the key... disappointed... Is there any skins that fit on the keyfob? I know there aren't any in ebay or elsewhere cause I have 2nd key that is like new so i want to protect that one at least... and i don't want the case... thanks |
I think all the cars from Acura that require a key use this same kind. Yeah it's cheap. The one problem I have with mine is after it's in the ignition, it sometimes won't stay straight, like it will start to close on it's own. I think the lock that keeps the key open is starting to loosen.
Originally Posted by rawger
(Post 14979267)
Okay, so I thought I saw a TSB for the issue we both have and I did. I'm not sure what year your TSX is, but from 09-12 they replace the key case to fix the lock problem.
http://techinfo.honda.com/rjanisis/pubs/SB/B10-008.pdf If that doesn't open, do what this thread says and the link is under 2010 that says: Retractable Master Key Does Not Lock in Its Extended Position. https://acurazine.com/forums/2g-tsx-2009-2014-143/2nd-gen-tsx-tsb-information-789358/ |
My unlock button and trunk button are starting to fade to black. They'll replace them????????
there are some key fob cases on ebay
Originally Posted by opboarding
(Post 14979293)
Originally Posted by djhtsx
(Post 14979295)
(Post 14979289)
http://techinfo.honda.com/rjanisis/pubs/SB/B10-008.pdf If that doesn't open, do what this thread says and the link is under 2010 that says: Retractable Master Key Does Not Lock in Its Extended Position. https://acurazine.com/forums/showthread.php?t=789358 |
Originally Posted by dwk331
(Post 14979358)
mine is 2013... i think i am going to scrap the silver so it'll be all black.. ithink it'll be better..
I think you might be right about scraping it off though lol. I've thought about painting it somehow, maybe plasti dip or something. Then you could change the buttons into whatever color you want! |
(Post 14979365)
Either way, you do have the same key as the rest of us, if they give you crap about it being a 2013, just b**** at them and tell them it's the same damn key regardless of year.
I think you might be right about scraping it off though lol. I've thought about painting it somehow, maybe plasti dip or something. Then you could change the buttons into whatever color you want! I think imma go with original color... besides button looks better with silver... and plasti dip is a good idea :) |
(Post 14979300)
I wish, but no. Lol. They replace the key case if the lock is worn down. But in the process, the back plate of the key will be changed. Open the TSB if you still don't know what I'm talking about lol.
Care to provide a link? I just looked and saw a bunch of covers for the older key models. |
(Post 14979372)
yea you're rite haha...
(Post 14979375)
link denied
Damn wtf u guys do to your keys... Mine has slight wear on the rear but the buttons are fine
Users error.
Originally Posted by Cu2Suspect
(Post 14979507)
Originally Posted by EricInMaryland
(Post 14980051)
Originally Posted by TSXy Luster
(Post 14980174)
Users error.
(Post 14981071)
Didn't know there was a wrong way to press a button.
Originally Posted by iCrap
(Post 14981100)
I'm convinced he just comes in and posts random shit just because :whyme:
(Post 14981062)
Not bad, but it doesn't have the cut out for the panic button. Shouldn't really matter, but that's just me being picky. Good find still.
They are just ok. Little bit of a Lint Magnet. |
True. Yeah I'd think that's also an issue since its silicone or rubber material. I think I'll give it a shot anyways. Thanks again.
(Post 14980051)
looks good with leather :) http://www.ebay.com/itm/321190403348...84.m1423.l2649 I might get this haha |
I might just scratch off the silver. Then paint the symbols with white/red paint.
(Post 14982475)
I also found this!!
That's what I thought would happen. The leather is probably too stiff to actually push down the buttons. Bad design IMO. And a rip off.
(Post 14982573)
I bought this as well. Did not fit well and pressing the buttons was difficult. Also bulky.
I will try to create a cover for my driver 2 key, which I still need to buy since my tsx never came with the 2nd key, dealers asking for way to much. |
(Post 14982573)
I have no complaints with my fob. I have jumped in the pool and lake with it and it continues to work fine. It is tough as nails
Originally Posted by sincitytsx
(Post 14984208)
i try to scratch off the surface of the silver area and it is rather difficult since it's so smooth.. but trying to get it off cause it looks ugly right now... |
Wasn't there a time others were trying to convert their regular key to a blade?
(Post 14979507)
