what is this in the trunk, is it a noise maker?
#41
The replacement of the specified clip has to do with safe operation of the SRS device.
#42
This thread is funny and another example of why you should never buy a car from an "enthusiast".
The "normal" buyer has a noise and they go to the dealer to get it fixed.
The "enthusiast" buyer jerry rigs the problem and ends up with a car that has 20lbs of microfiber rags in the trunk or a bunch of unsafe airbags.
Either live with the noises or fix it properly.
#43
TSX AMG Type //M i-VVT
#44
Everyday I'm rofling
<<<@!1!@>>>
Unless I'm missing something that rear panel shouldn't affect the side air bags. Start at 26 seconds.
#45
Yeah.. looks as if it won't affect anything. But maybe if the clips aren't in it will fly off and could hit someone.
#46
Some manufacturers use different clips that look similar to delay or allow speedier release of certain trim bits - or like iCrap said - to keep the trim bit from flying about and slashing either an occupant or an airbag.
When a manufacturer mandates the replacement (instead of re-use) of a fastener then there is a good reason behind that mandate.
#47
If you (I'm speaking generically here since I know that you know this) have a legitimate significant issue that a dealer recognizes but won't correct and that isn't present on a new car on the lot, then either go to a different dealer or call Acura.
#48
For small stuff like a rattle in the trunk I just don't think it's worth the time going through the hassle. I checked with the 2 dealers near me that I know of that are somewhat close to me.
My bigger issue is still the "TMPS System fail" light that comes up when it's cold outside, I took the car in twice though and they said they had fixed it both times (they said they changed some battery)
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
