Wagon: anybody remove overhead seatbelt?
I find it annoying as hell with the window/s open on the passenger's side — the damn seatbelt flutters like a loose part on an airplane. I never use back seats, keep the backs down so the dog has more room. I could simply cut it, but my luck I'd be left with a streamer and put a hole in the headliner. Perhaps you have already solved this problem... and, can tell me how you did it. Thanks.
Jimmy
Jimmy
EuroRspec (03-30-2017)
There are essentially 2 buckles for the middle belt - one that's the initial anchor and the other that's the buckle the passenger fastens when in the car. The anchor buckle has a 1/8" wide slot in it that you press the passenger blade into in order to release it. Next, the entire thing reels into the ceiling and there's a slot there to stick the anchor blade into and you're done. You'll hardly notice it.
Thanks you guys.... Dumb C'hit here never really looked at it?! Probably 5min after I bought it, I lowered the seat backs, carved up an old oriental to fit ...and started bitching. Clever little buggers; the solution is really quite creative. Of course, I also failed to RTFM. Thanks again.
Jim
Jim
