Sport Wagon Rear Jacking Point
Old Jun 26, 2012 | 08:09 PM
scheißterhöffer's Avatar
Does anyone know if the Sport Wagon has a rear center jacking point? On my gen 1 sedan, I always jacked up at that hook in the center in the rear. The wagon has a similar hook point, but I have a Curt hitch installed in such a way that I could not use that hook, without damaging the hitch and/or mounting hardware. Is there somewhere else I can do this? I've never been able to jack on the side points by the wheels and still get a jack stand in there as the spacing is too close. Can anyone tell me a rear center jacking point, or where on the sides I can jack and still get a stand under there?
Thanks.
Old Jun 27, 2012 | 11:47 PM
bpr0422's Avatar
if you have protective silicone on your stands, you can try placing the stands directly under the frame
its easy to spot, since the subframe mounts to it..
just know that because its inside the width of the car, the car will not be as stable as if it was sitting on the jack points.
Old Jun 28, 2012 | 09:30 AM
robpp's Avatar
Graphite Ghost
i can lift the whole side up from the front side lifting point with my 3 ton jack. then get a stand under the rear side point.
Fabian43
Jul 13, 2016 09:07 PM
HairyMonkey019
Apr 22, 2016 10:50 PM
Dunnik
Sep 15, 2015 11:52 PM
jliu6789
Sep 8, 2015 08:02 PM
NSolace
Sep 3, 2015 08:02 PM
