Reset Maintenance Minder twice by accident
I reset my maintenance minder after I rotated my tires last week, then tonight I changed my oil, and reset it again. So did the second time I reset it mean that I am skipping my next service, which I think is B1? If so, how do I get it back to the correct timeline (after the first A1 service reset)?
The manual doesn't really say. I assumed there was a MM of A1 which is why you rotate tires and change the oil. When you reset the first time, the A1 would have disappeared. Your oil life indicator would be at 100% at that point and you changed it a week later (assume the oil life is still display 100% - even when it's between 91%-100%), the second reset probably would not do anything except resetting the oil back to full 100%. Check with a Tech at the dealer to be sure.
08_UA7_Gr33k
02-11-2016 02:17 PM
