Replacement Key Fob?
So I just purchased a 2012 TSX SE and it came with the OEM Driver 2 fob and valet key. What is the most cost effective way to get a second key made? I see non-oem knockoff switchblade fobs with blank keys on them for under $30 but could a locksmith or dealer program this type of key?
They *could*, but it's hit or miss if they'll want to try with an aftermarket key. A locksmith would likely be more willing than a dealer.
In any case you should be able to get the key cut at most places but will need somewhere that has the Honda MVCI to register the key transponder to the cars PCM. Honda/Acura dealers and high tech locksmiths will have them. Good luck! |
Dumb question, but I bought my TSX used and it didn't come with a valet key. Is there a way to lock the trunk release from inside the car? If so, how? Otherwise, I don't really see the point in having a valet key.
Thanks. |
Originally Posted by Lewal
(Post 15814664)
Thanks. |
Originally Posted by passmaster16
(Post 15808463)
