PCM update for TSX
PCM update for TSX
Yesterday I bought my car in for engine pinging issue again. Have 09-041 TSB done already, but no help. Dealer said there is a PCM software update available, then they went ahead to update it. I don't know is this going to help to elimate my pinging issue or just another "BS" from dealer. Dose anybody know what eaxtly PCM do? Dealer told me PCM stands for powertrain control module. It is a piece of software to control your transmssion. Is this going to help my pinging issue? I hope the update will not affect my fuel economy.
Updating the firmware in the PCM can most definitely correct your ping problem. Since the reprogramming may retard timing to achieve that goal, it may also have an adverse effect on fuel economy. There are other parameters which can be tweaked in combination with timing to achieve the same end and hopefully the effect on fuel efficiency will be held to a minimum. However, these kind of software updates are usually only implemented by the dealer when a customer complains, since they may ding fuel economy.
I still hear hint of pinging while i drove off dealer lot. I will keep you posted after a week drive too see it will learn from time to time. I also worry about my MPG will drop, because in order to eliminate ping or knock, computer has to supply more gas. Hopefully Honda engineering team are smart enough not to screw up the MPG. because of gasoline now is sky high.
first day test drive after PCM update, I felt car runs more smoth than before. I did not hear ping so far with audio on with volume 5. I will try to turn off audio to see any difference when I am on the way home.
When I had my TSB done to resolve the pinging issue, they updated the PCM as well. This combination, coupled with the fact that I've never put in anything less than 93 grade gas, gives me no pinging...
May I ask what brand you use for 93? Do you always use name brand or others? I really don't want to stick with Exxon due to high gas price now.
Are the pinging problems with a V6 or I4? I have a new wagon - which is only available with the I4 - and have no pinging problems using the 91 octane that is available in my city. I only have 1000 miles on the TSX Wagon and I'm getting 30+ mpg for my in-town driving! I'm impressed since it is only rated for 22 mpg. Again, no pinging, but I don't want to take it in for a computer re-flash and have them ruin my excellent mileage.
Enjoy your new ride.
You should use Top Tier Gasoline only. In Maryland, that's Chevron, Texaco, Shell, Mobil, and Exxon. Find your local retailers here: http://www.toptiergas.com/
Not good
Sup y'alls ?
Got my PCM update done yesterday on my 09 4 cylinder. Thus far fuel consumption looks like it has been increased. Driving 3 city blocks on my way to work this morning I noticed my range dropped 6 km. it was about 3 deg Celsius here in Toronto this am. My hiway fuel consumption looks like it has been affected as well. :-(
I just filled up with Petro Canada 91 and will keep a close eye on this tank. I usually get a little over 500 km on 95 % city driving.
Will keep you posted at the end of this tanks run.
E
E
Not Looking Good
Sup y'alls ?
E
E
First full tank is done ... 450 KM
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
Granted we had a cold spell of -20C for a few days it has since warmed up and is not looking good. Even yesterday at 7C and no heat on the range was clicking down like a countdown timer. I will try 2 more tanks before I mention this to the dealer.
What do you think my fellow Ziners ?
thanks ED
thanks for the reply ED ... I will try a couple more tanks.
I'm not going crazy here as I always flip my Range on when I'm driving so I can get an idea of how much gas I'm eating up or saving. I wish the Range would stay on by default without having to push the button everytime I start the car.
Since the upgrade I've noticed some really erratic movement (up\down) on the Range .. more movement than before as if it's recalculating more often.
Driving style is still the same and I'm drving 6 speed manual shifting at 3000 RPM. I'm thinking that 450 KM out of a 70L tank, for a manual tranny 4 cylinder in horrible.
What do y'all think ?
All looks ok after a few tanks
First full tank is done ... 450 KM![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
Sorry Ziners for the long wait, have not had a chance to update. Couple of tanks later and here are the results keeping in mind that Toronto has a had a warm spell over the last couple of weeks of which I did not use the heater for the most part.
Details ...
Driving out of the Petro Canada gas station after $80 fill-up Range display indicates 735 KM. Over the next week (95% stop and go city traffic) the stats at the end of the tanks run is as follows ...
Trip A -> 545 KM (Trip A I reset on every fillup)
Range -> 153 KM (woo hoo ... can still drive another 100+)
Trip B -> 2500 KM (Trip B I reset every 5000KM with oil change)
L\100 Trip A -> 8.8 L\100 (Avg L\100 since last fill up)
L\100 Trip B -> 9.0 L\100 (Avg L\100 since last oil change)
So 545 KM, with 153 still left on the Range, avg temperature over the week period 5 to -5 C, shifting at 3000 RPM ...
for winter driving (on snow tires) with the car using more fuel before it is warmed up and minimal heat ... not bad, I'm ok with that.
![Yum](https://acurazine.com/forums/images/smilies/yum.gif)
ed_423 (02-03-2012)
Details ...
for winter driving (on snow tires) with the car using more fuel before it is warmed up and minimal heat ... not bad, I'm ok with that.![Yum](https://acurazine.com/forums/images/smilies/yum.gif)
Details ...
ed_423 (02-03-2012)
Thanks for calculating for the UK members since they are the only ones here thinking in imperial gallons.
My calculations are correct for comparison with US members.
Close but not quite. Canada measures mileage in liters (or litres) per 100km and not in MPG. Accordingly, your Imperial MPG numbers just muddy the waters. I recalculated for the US members.
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
I guess technically we don't calculate "mileage" by definition. We calculate fuel consumption where the lower the number is better. That's just bass-ackwards.
Since E-ManN is from Canada, both sets of numbers (mpg US and mpg CDN) are correct.
Jamus22
06-11-2023 10:08 AM
GWEEDOspeedo
01-15-2016 10:39 PM
