new C/D test TSX 0-60 at 6.7s
Old 06-02-2008, 04:17 PM
  #41
You'll Never Walk Alone
iforyou's Avatar
They already did:
http://www.roadandtrack.com/article....rticle_id=6833
Old 06-03-2008, 01:08 AM
  #42
SSFTSX's Avatar
for Accord it is 0-62mph Auto 9.5 second. and 7.8 second with manual. i think these are more realistic.
http://www.honda.co.uk/accord/#specs
Old 06-03-2008, 01:36 AM
  #43
iforyou's Avatar
Those are just conservative numbers. Honda has been very conservative with their performance numbers recently, as we can see from the s2000, accord, and TL-S. And now this is applying to the new TSX too.
Another company that is conservative is BMW, they claimed the 335i would do 0-60mph in 5.5s, when in reality many mags have gotten high 4's.
Of course, getting those numbers require hard launches which we won't do on a daily basis. But then if one wants to see the maximum performance, I think hard launches are required, otherwise, we would be looking at 5-60mph numbers instead.
Old 06-03-2008, 08:48 AM
  #44
dom
dom's Avatar
Originally Posted by iforyou
0.8 seconds is quite the difference. R&T's time sounds a lot more realistic IMO.
Old 06-03-2008, 02:06 PM
  #45
Colin's Avatar
Received 1,012 Likes on 567 Posts
I'd split the two. If you're willing to dump the clutch (as much as the check valve will let you) AND you have a cold day (testing in the arctic circle) AND you are Mario Andretti, you might get the C&D time. No matter, a 'high 6 low 7" range is good for this segment. Would it be safe to say the auto would be under 8?
Old 06-03-2008, 04:26 PM
  #46
boy1pow's Avatar
under 8? no way
i dont think the auto would be under 8. i would give a one hundered dollars next person i met random on the street if that car could run under 8 !!
Old 06-03-2008, 04:32 PM
  #47
Colin's Avatar
If C&D tested it, it might. What did the old auto run?
Old 06-03-2008, 08:21 PM
  #48
iforyou's Avatar
I don't recall seeing any test on the AT.
Old 06-04-2008, 12:33 AM
  #49
boy1pow's Avatar
old tsx time
06 6spd - 0-60mph - 6.9secs
06 5AT Full Auto - 0-60mph - 8.7secs
06 5AT SportShift - 0-60mph - 7.7sesc
http://www.vtec.net/articles/view-ar...&page_number=4
the old auto acceleration is 8.7 with full auto. i dont think it will ever go under 8, unless they use A- vtec engine.
btw, i saw a 09 tsx on the road today, it actually looks pretty nice.
Old 06-04-2008, 12:45 AM
  #50
boy1pow's Avatar
sportshift
did anywhere post the 0- 60 time of sport shift yet? i would think the sportshift could run under 8! id buy tsx for sure if it could run 7.5 sec. with sportshift!!!!
Old 06-04-2008, 06:58 AM
  #51
2010 6MT non-tech
frescagod's Avatar
i find it amusing that you guys won't buy a car if it runs the 0-60 in 8 seconds, but you WILL if it runs 7.9.
the TSX is not a 0-60 car! it's a decent handling, relatively practical, somewhat sporty sedan. it's not a sports car. it's not an M3 sedan.
do you really think that a couple of ticks on a stopwatch difference on a TSX should matter? do any of you seriously race/autocross this car?
Old 06-04-2008, 12:56 PM
  #52
boy1pow's Avatar
indeed 0-60 is not everything , but it is something. the tsx is decent handing. good for daily driving,with aload of tech. and it would be a killer if it also goes FAST. i serously thought they would use A-tech engine for 2009 tsx a year ago, i was deadly waiting for it.
over all its a very good deal. with a little faster acceleration id be even happier.
Old 06-04-2008, 03:46 PM
  #53
iforyou's Avatar
Wow 0-60mph in 6.9s, seems like 6.7s doesn't sound too crazy....
Old 06-04-2008, 06:33 PM
  #54
2010 6MT non-tech
frescagod's Avatar
from that vtec.net article:
"We found that the easiest way to extract the best acceleration figures was to upshift without lifting, but at the same time we must emphasize that this is NOT a recommended technique for daily driving. This WILL lead to accelerated wear on your transmission and can also increase the probability of catastrophic mis-shifts. We only tried this technique on a couple of our acceleration passes, but according to our results this technique clearly resulted in nearly a 0.5 second improvement in the 0-60 and 1/4 mile times."
lol, they didn't let off of the accelerator while shifting. you fellas have fun doing that to shave a half second off your 0-60 launches!
Old 06-04-2008, 06:40 PM
  #55
wackura's Avatar
That's called power shifting, I figure most cars will go faster if you do that since the flywheel will pull at the clutch as they engage but since it ruins the car I figured nobody bothered to do it for any reason.
Old 06-05-2008, 01:03 AM
  #56
iforyou's Avatar
lol can't try that at home cause I have AT...:P
nj2pa2nc
08-19-2016 06:18 AM
johnalfa
11-05-2015 06:44 PM
kev87a
10-18-2015 02:03 AM
95oRANGEcRUSH
09-25-2015 12:50 PM
Eggs999bacon
09-24-2015 10:08 AM
Quick Reply: new C/D test TSX 0-60 at 6.7s
