Installing oem spoiler
I just purchased this spoiler
http://www.ebay.com/itm/171260556488?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
it has two screws on each side, but i can only drill a hole through the top whole since the bottom hole interfers with the trunk rubber stopper....
my concern is that if i screw in the top whole, the bottom of the spoiler will lift up...
is there a way i can screw it or a glue i can use to glue that part of the spoiler to the trunk?
You need to follow the instructions on how to install the item safely & properly.
Acura online store - Select your vehicle to view the installation or DIY instructions for an Accessory
Ok I will check those instructions out. I wanted to wire the spoiler light to my brake light. Is this possible ? Because I noticed my brake wire has three plugs (red black and green) and my spoiler only came with white and red plug
Why would you buy that spoiler and not an OEM for much less?
Genuine Acura 09 13 TSX Rear Wing Trunk Spoiler Palladium Metallic Silver | eBay
Are these not true OEM or is there something special about the one you purchased? (if you search you might be able to find your color, I just picked a random one.)
My 01 accord had a OEM spoiler attached later on I think (I bought used). The trunk SLAMMED hard. A few times while I was getting things in/out. That was the worst!
I only knew about that OEM spoiler because I was wanting one myself. I never pulled the trigger though because I can't tell if I reallllly like it with the spoiler or not. Normally I do but I just can't decide on the TSX.
BoricuaTL
04-08-2016 01:08 PM
