High idle after changing spark plugs
Old May 23, 2020 | 10:13 PM
chaospy's Avatar
Hi all,
I changed my spark plugs on my 2011 TSX SportWagon with NGK iridiums. I replaced them with the OEM ones listed on the manual.
I have noticed that when it cold starts, it high idles at 1500rpm and does not drop till I shift into drive or reverse.
1) I inspected the hoses and it looks like nothing is off/ripped
2) Reset the ecu by disconnecting the battery or 10-15 minutes.
What do?
Old May 23, 2020 | 10:46 PM
Look up idle relearn, its normal id you disconnect the battery and after driving around normally, you should be okay again
Old Jun 21, 2020 | 08:28 AM
Jason46's Avatar
Does it still idle that high after there is heat in the engine? Mine idles around 1,500 for a minute or so after a cold start.
bbsitum
Apr 2, 2020 05:48 PM
khawaab
Jun 29, 2016 11:50 PM
xakura21
Jan 9, 2013 05:12 PM
type-s09
Dec 22, 2006 12:35 AM
DEEZNUTZ_RENAMED
Jul 8, 2001 03:02 PM
