Hidden Gems?
Hidden Gems?
Wednesday I picked up my 2011 TSX Sportswagon with Tech Package. Are there any easter eggs that may not be obvious off the bat?
I know about the side view mirror in the R position tilting my passenger's mirror down when in reverse. I know about the auto windows down as well.
Now I just need to sell my 2005 TSX.
The following 4 users liked this post by justnspace:
VTEC just kicked in, yo!
easter eggs? hmm...
Not really an easter egg, but I guess in the driver seat, beside your right leg there's a tiny pocket along the side of the console/wall. You can place pretty small items in there? Vice versa for the front passenger.
yeah... not really an easter egg lol
using your keyfob, when you unlock twice and hold it down, all the windows will roll down
fujiteam (10-28-2014)
the best one is when i look at my reflection in the rear view mirror. time stands still
ROTAREDOM
Best easter egg I found was after 3 years of owning the car. I could adjust my brightness for the radio and meter haha. I turned it as high as I could once I found it on the gauge cluster.
TSX AMG Type //M i-VVT
You will go crazy trying to find the source of all the little rattles!
Insert your key into the drivers door and turn it to the right (or left) twice and hold down on the second (or first), All your windows will go up and your sunroof will close.
Also, have your mirror adjuster turned onto your passenger mirror and it will point down whenever you put your car into reverse.
This is on my 2012.
This is on my 2012.
Received 7,772 Likes
When your wipers are on and you shift into reverse, the rear wiper will come on.
For the 2011 Wagon, look in your trunk and you will find a spare!
dave_88 (10-20-2014)
Dude
The RL had it and, quite frankly, most found it to be a bad idea as it doesn't allow you to see traffic coming up on you.
Ideally, you could decide which side tilted down but with the TSX it is the passenger side and with the RL it was both.
Thanks everyone. The passenger mirror was really cool to discover. I rented a Volvo that did it, but it was much slower. The rear wiper I will have to check out. I assume there is still the courtesy wipe when releasing the brake. The moon roof being tied into the rest of the windows when rolling down is a nice addition. I think hitting the moon roof button once is one of the best improvements, I hated holding my old one.
Thanks for all the advice. I picked up the car then drove it about 800 miles int he first two days. Unfortunatly I have to be away from it for a week now on travel.
^ I just found that out like last week lol.
Not hidden...but these make a drive more pleasant...
1. Sitting on towel so i can use the seat back heat and not feel the butt heat
2. Using a visor cd storage accessory so i can extend it to block out sun that sneaks through end of visor to pillar.
The lower left hole for opening the hood was on the Gen 1 as well. Lots of people miss it, hopefully that helps someone else. I already put it to use to put the washer fluid hose back on the clamp hidden near the hinge.
I've found you dont need to hit the vol/on button if your stereo is off and you want to listen to it.
You can hit the button corresponding to the component you want to listen to.
Example: Hit the xm button and the last xm station goes on.
Save your driver's seat settings to slot 1. If you ever change the driver seating position, the next time you unlock and open the door, the driver's seat automatically goes to the saved setting. Pretty sure it works with key fob 2, and setting #2. It's convenient when someone else drives the car temporarily (when in dealership).
Silly ones, but amazingly some people had no clue about them:
- Gas door has a little place to hang the gas cap
- There's a button on the trunk above the plate to pop the trunk open when the car is unlocked (I found out this 6 months after owning the car :/)
- Foot well lighting mod, link>> https://acurazine.com/forums/perform...d-free-880697/
- Turn off DRL (remove fuse, no second effects)
- Armrest slides back and fort
- To enter diagnostic mode in you radio (non navi) press and HOLD 1 & 6 then TURN ON. There you can play with some settings including turning ANC on or off, not sure if it shows ground speed in KPH like the accords do
If i remember more I'll post them
On the fastest intermittent wiper setting, the wipers are in intermittent mode when you're stopped, then go to regular slow speed when you start moving. This might be common on current cars, but I've never experienced it before.
I wish I had the shallow storage on the arm rest.
I found the vent for the arm rest compartment.
Can you explain the ANC thing to me pls
For now, I can live with an air compressor and can of goo. But if I were driving through death valley, I'd definitely want a spare.
Now if only it actually made a difference...
Not sure if it's on by default. But no, it basically does nothing.
