The Graphite Ghost: TSX Wagon
adamsrotors (12-28-2012)
99blackhatch (08-09-2013)
#210
they sell MANY stock patterns and they do custom work as well ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
and the names are mouthful but well worth it.
go check out the gallery for pics of some of the patterns
I have had good luck with DIMPLED rotors rather than drilled and I didnt want to personalize them too much so went with something that was somewhat normal
#215
i have a few new mods in the works.....and the brakes still need another BED-IN set LOL
RV6 I4 downpipe and Vibrant reso to rid it of the rasp. these are shipped....on the way/
and as soon as we do tax returns this year I will get me some TEIN SS and related hdwre/
i did finally mount my V1 using a Blendmount and the Invisicord from my Jeep.
all rather simple really. I DO WISH it could go up even higher......am thinking I need to try and slide it around a bit more until 100% comfortable/
V1 that I have owned since 1998....has had a few updates but that was initial purchase date LOL![Cry](https://acurazine.com/forums/images/smilies/cry.gif)
the left most wire is power and the next is ground.
side view: V1 with Blendmount mirror mount and Invisicord wiring direct to the mirror power.
![](http://i300.photobucket.com/albums/nn11/robpp/The%20Graphite%20Ghost/V1%20Blendmount/2012-12-27_15-05-37_274.jpg)
front view
front view
![](http://i300.photobucket.com/albums/nn11/robpp/The%20Graphite%20Ghost/V1%20Blendmount/2012-12-27_15-07-33_981.jpg)
#216
Former Sponsor
#220
how about some more details.....
looks awesome.....tell me how.............PLEASE
http://www.tein.com/tech_info/b90-cw2.html
#223
it can be done without any leaks and such?????
lets see some pics of what you did bro
#224
yeah i did 245/35 19 conti dws IIRC. i bought the wheels from racing gear on 'the club'. he WON them and never used them. i even bought the tpms mount from work so I wont get any lights and such.
where can I get some cheap center caps that will work on the WORK?
I have some custom resin ones that will stick to what is there....so I rather not F UP the original work ones? I dont want to pay a lot either cause I will paint them and cover them over
#225
ebay, search for your MM and "universal center cap"
ton of great blank center caps
#227
what gotta keep the work caps but its your car. I did tmps sensors in mine too hopefully you wont have the same problem im having i need to get the sensors adjusted cause there all over the place even though the tires have the same pressure in them. so now when it gets cold my car bitchs about low pressure just food for thought to check when you put them on.
#228
oh wait.......i gotta keep a certain wheel cap on but guys put HONDA grilles on Acura and way more interesting things too.
lets remember one thing: I don't HAVE to do anything to satisfy someone else. only myself. i had CUSTOM center caps made to go with my re-badge theme. like them or not/
mine tpms are all in the same place; attached to the long L shaped air valve. In theory I dont see any difference if mounted center of wheel vs. outside lip......but they are the ebay sensors that many others are using with no issue INCLUDING Ceb so we'll see.......and if non-winter keeps up like this we may SEE sooner rather than later![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
they had 2 days above 60 in the 5 day forecast!
#236
yeah i work for a honda dealer and was able to test a few channels out. im using ones off of a 2012 pilot. its longer but jus need to cut then. glued a piece of plastic on the end of the drip rail thats shapped to the channel. then i plasta dipped the end
#237
if your going to do this be carefull when you remove the caps on the roof rails that cover the bolts. like i said i broke 3 of them and there not cheap to replace if i ever want to reinstall them. i followed how the book said to remove it but they still broke
robpp (01-21-2013)
#240
74316-sza-a01zb is left side
74306-sza-a01zb is right side
Put towels on the roof. I put some small scratches on the roof when I was doing it. The channels have metal inside of them.
