Full Synthetic oil question
I switched oil to Synthetic for my last oil change. according to the vendor, it seems like Synthetic can last 10,000 miles between the oil change. My question is our MID seems not recognize whether it is traditional or Synthetic oil. The oil life drop to 15% at 5500 miles. Should I follow the MID or just reset the MID and wait until 10,000 miles? Can someone who have been used Synthetic oil before give me some advice? Thanks.
3G TL/2G MDX Owner
MID system does not know you put synthetic in.
according to the OM it says MID or 1 year as the standard of care for OCI regardless of type of oil used.
if you want to get into the science of your oil from your engine, you can send it in for a blackstone oil analysis. many guys on the 3G TL side have done this to assess the condition of their oil. some follow the suggestion of what they say (usually say you can go longer based on what they found) or follow the MID.
i use synthetic in my TL...i follow the MID or 1 yr.
justnspace (03-01-2014)
At 5000 miles it is black nasty looking stinky contaminated oil I never go more than that on the my full synthetic oil and I never use 5w20 that is gas milage oil 5w30 for me with turbo I now use 5w40
Reorge (03-08-2014)
I have an 09 rdx - I also use full synthetic oil. I have the same question/concern. Synthetic oil can go at least 10k kms between oil changes but the mid usually calls for oil changes after about 5km.
Should I follow the mid or just keep it going until 8-10km? I do mostly city driving but think following the mid may be changing the oil too soon ( I guess that's not bad thing)?
3G TL/2G MDX Owner
^^you have a 1G RDX with a turbo. synthetic is required. it is known that the 1G RDX has shorter than usual OCI like around 4k miles. if drive more city and idle a lot your OCI will be shorter (4-5k mi range...maybe even 3500 on the RDX). follow the MID.
justnspace (03-04-2014)
LOL I don't know anything I Just started stupid mechanic job in 1982, how many Honda engines did you replace piston rings on last year because of 20w oil and MID 7000 plus recommended oil changes. I did well over 20 (oh and the bearings look like shit also) run 5w20 and follow the MID please that's how I make my house payment
The following 2 users liked this post by UTAH TSX:
TERRY A KHAN (03-03-2014),
waaasobe (03-02-2014)
2010 TSX
BTW...you know they make 0W-50 and 5W-50
I bet these pour like honey tho...seems like it would be tougher on engine startup? 0W-20 and 5W-20 are like water.
you can,however, draw a conclusion from owners not changing their oil on time, on a regular basis, leading to catastrophic engine failure, but that would be on the owner. and not the oil.
I do agree with you that the 0w-20, that honda has decided to push is for CAFE reasons. (fuel economy)
Everyday I'm rofling
Educate me.
0w-20 was chosen for the 2011+ TSX models for fuel economy(as I read). What makes it better for fuel economy? Since it is thinner? Why wouldn't they use this originally in 09-10 years? Are there downsides to using 0w-20 over 5w-20?
honda switched their whole fleet to 0w-20, the exception of the turbo RDX.
yes since it is thinner, in theory, you will gain .1 mpg.
times that by the whole fleet and Honda has achieved their CAFE regulations
no downsides, as at temp the 0w-20 is the same weight as the 5w-20.
0w-20 is a synthetic.
ive ran a full synthetic 0w-40 before.
right now im using redline 5w-30
Reorge (03-08-2014)
I HATE OIL THREADS I'M DONE JUST CHANG THE CRAP AT NO MORE THAN 5K AND USE GOOD OIL
It's not catastrophic engine failure the oil rings get all gummed up and stick in the piston then they use oil like crazy and people never check there oil and at 7000 miles it has 2-3 quarts left that is nasty stuff and it gets worse and worse by 100k it burns a quart of oil every 1000 miles (anyone on here checks there oil we tend to like our cars 99% of people just drive and put gas in) the k24 is the worst by far but we get a few v6's a month on the new oil consumption misfire recall now
calm down.
[QUOTE=Simba91102;14907256]I agree that we should kill this thread (though that's all I agree with from this . . . fellow). It's obvious that there are many opinions on the oil issue, and we've beat it to death over the years (with the same conclusion: to each their own). Mine are based on experience and science, others maybe not so much. Whatever.[/QU
Guess what I'm doing today Simba, this is a non scientific view of thin old oil LOL
2008 accord 123k miles faithful customer changed oil at 15% like clock work, bought car new from us
musty hustla (03-22-2014)
UTAH TSX (03-05-2014)
justnspace (03-10-2014)
I Spit On You.
[QUOTE=UTAH TSX;14908291]
So that damage was from using 0 weight oil? I'll assume your dealership did all the oil changes?
I just find the story and the pictures hard to reconcile.
[QUOTE=EricInMaryland;14933120] It's what happens to some k24 engines when you follow the oil change recommendation the mid gives you, this car goes about 7k miles before it turns to 5% k6 miles 15%, not all cars do this but enough to see this on a regular basis
Let's me add my confusion between using 0-20W and 5-20W. From my understanding the lower number is at 0C or lower and the upper number is at 100C. So if you live where it never gets below 0C, on a cold start the oil is probably at 5W or higher. Once the engine warms up, it moves up the weight scale. Since the 20W is at 100C (212F) and engine oil under a cruise load tends to be 20F-30F over the coolant I would expect 0-20W and 5-20W to act the same.
So unless you need that 0W when it's freezing, 5W is fine and unless they decide to send your oil out for testing they would never be able to tell the difference between 0W and 5W. 5-20W around here is cheaper and easier to find in any brand or type (normal/synth) of 0-20W. The dealer sells the Honda blend 0-20W for $7 so if I can find M1 0-20W at an equal price I will use that. It periodically goes on sale for $5.50. I know I need to have receipts for 0-20W for warranty so I am stuck there with 0-20W. Too bad none of my other cars use 0-20W (HHR SS used 5-30W and the Duramax uses 15-40W.)
I see zero downside mechanically to 5-20W over 0-20W. I doubt x-20W is pretty thin stuff but I assume Honda wants warranty repairs no more than I do.
mada51589
05-03-2022 08:54 PM
asahrts
09-04-2015 05:55 PM
