Front license plate relocated
I have moved my front license plate from the bumper to the lower grill. The plate is too tall, so I took my plate to a sheet metal shop and had them shear off 1/4" from the top and bottom ($5). I removed the OEM mounting bracket, and it happens to have two bolts mounted in the grill. I bought a universal license plate mount bracket made by Bell ($3 at Walmart), shaved off 1/4" on the top and bottom, purchased a couple #10 1" bolts, and mounted it. I then trimmed the flash on the bumper mounting holes and put in two small black plastic plugs (autozone - $1) 10 minutes, $10. What do you think?
Looks much better. You know what looks even better is removing it altogether, which I did. Front license plates are required in Illinois/Chicago but I've been running without one for the last 10 years now without any issues.
I agree about running without, however, I am in a more rural area of MN and we have a couple of Barney Fife's. Been pulled over twice, given warnings twice. You have to make an appointment to show them it is attached. MN has increased the fee to $215!!!!
A minor concern in putting the plate where I did could be overheating if you live in a hot climate with lots of stop and go traffic, but even then, not much more surface area is taken from what the OEM mount does. Nothing factual, but I would think I have reduced the drag coefficient as well?
Here is a larger pic of the frontal:
Lol @ drag coefficient reduction. Probably saved you 0.0001 mpg, but hey every mile counts these days. Close up it looks real good, but from far away it looks like a baby whose front teeth are growing in. It is probably because of the contrast between the white plate and the dark grill.
Silvermoon_Knight
10-22-2015 06:25 PM
darksky
09-05-2015 03:11 AM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
