flush look?
Old Jun 3, 2012 | 12:44 AM
12TSXtech's Avatar
flush look?
i want to get a flush look on my TSX. Can some people give me some info on how to get that look? what size rims will look best for that look? offset recommendations?
Old Jun 3, 2012 | 12:52 AM
PyroDave's Avatar
dude, search feature....
Old Jun 3, 2012 | 03:37 AM
ed_423's Avatar
SeeYou2Crew #2
17x7, +60, with 275,35,17.
you MIGHT need to roll your fenders.
-9.5 camber should do
Old Jun 3, 2012 | 01:57 PM
ttk5's Avatar
Vancouver B.C.
If you want just regular flush. any wheel with an 8.5-9.5 width with a 35-45 offset will probably do it. Not hating, but you seem new to the scene so I wouldnt recommend going too aggressive for your first setup
Old Jun 3, 2012 | 02:58 PM
ed_423's Avatar
SeeYou2Crew #2
^ +1, i'd do A LOT of research before you know what you are getting into.
Old Jun 4, 2012 | 12:12 AM
12TSXtech's Avatar
Thankz for the input guys, i appreciate it.....yeah im very new to this stuff...i just wanted to get some info on the flush look....im not planning on doing it anytime soon because i know i got a lot of more research to do before i do anything
Old Jun 4, 2012 | 08:19 AM
ceb's Avatar
ceb
There are lots of reasons why the car manufacturers are using a particular offset and wheel width on a car. In part it has to do with suspension travel and geometry. You start bringing the wheels out more then you may start to physically impact travel and a wider track may put additional stresses on the suspension bits and could cause warranty issues.
Old Jun 4, 2012 | 11:22 AM
ttk5's Avatar
Vancouver B.C.
^ that is very true..which is why aggressive fitments are not for everybody and you really have to know what your getting yourself into. And you have to have an open budget because there seem to always be complications with these types of goals that need to be addressed immediately....or just plan very very well
Old Jun 4, 2012 | 11:24 AM
Stylinhonda's Avatar
CR
Any fender rolling or anything needed for this?
Old Jun 4, 2012 | 11:25 AM
potmilkz's Avatar
function and forum, do not sacrifice camber just to get that flush look, its not worth it at the end because you will be forking out much more than you really bargain for
Old Jun 4, 2012 | 11:27 AM
tobwac's Avatar
depends on how low you wanna go but most likely you wont have to roll any fenders
Old Jun 6, 2012 | 03:23 AM
12TSXtech's Avatar
Ohk I see now...thanks for the info on the flush look....I'll def give it a second thought now that I know what to expect
Old Jun 6, 2012 | 11:23 AM
PPower's Avatar
The rears are sunk in a bit compared to the front and need 10-15mm spacers to become equal to the fronts. Some people go with a wider rear wheel instead that gives it a deeper lip and that RWD look, but then you can't rotate your tires F to R and throw off the handling characteristics compared to a square setup. Form / Function
mada51589
Jan 9, 2025 04:40 PM
adrian_s2k
1G RDX (2007-2012)
23
Jan 12, 2016 04:25 PM
hashbrown
Sep 29, 2015 12:13 PM
Ratheruneeq
Sep 28, 2015 07:41 AM
STL TL-S
Sep 23, 2015 08:52 PM
