Disabling electric steering assist?
I downloaded the manual and was wondering if there was a way to disable the electrice steering assist. There are the the fuse box diagrams with a fuse for the power assist. Anyone tried pulling this fuse and see if the car will throw errors?
Just an update:
I did a little googling and found out Audi and VW has similar "servotronic" assist. Some owners are going under the dash and pulling out the relay and/or pulling the servotronice fuse out of the fuse box.
BMW also has a steering assist and they unplug a wire under the dash that feeds vehicle speed into the eletronic assist module.
The electric assist eliminates the hydraulic power steering of past cars. I'm wondering if the fuse was pulled if all power steering would be lost. Advanage of electric assist is that you dont need a to run a hydraulic pump off the engine anymore and you save on fuel/ gain power there. Similar to when they stopped running fans off the engine and switched over to electric fans. Most VW/AUDI/BMW drivers complained when you were right at the switch point of the system (more assist/less assit) and began to slow or speed up that the steering would feel very inconsistant.
Originally Posted by 09TSX
thunderbt3....I am not sure I'd feel comfortable tinkering with the car's steering but then again, I am not much of a tinker kind of guy ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Far too much liability. You know that one accident would put all the 'burden of proof' on Honda to prove that the update did not cause the crash.
- Go to your local Acura dealer. Find the used section of their lot. Look for a 2004-2008 TSX. (If you can find one in the new section, so much the better.)
- Find a salesperson. Trade in your car for the used TSX.
Originally Posted by darmok
Darmok's Sure Fire Two Step Process For Disabling The Electric Steering Assist:
nice
I took delivery of the car and I've gotten used to the steering (20 min drive home). One thing I did have a concern about is that I was in a slight right turn. I turned the steering wheel maybe 10 degrees and the steering didnt seem like it wanted to return to center. Not sure if it was something on the road causing it or if it was the car. I'll do some test and if the problem persists, I'll be making a visit back to the dealer.
thunderbt3....I have heard that some GM products had similar "experience" in the past when they introduced these to the market and I am curious if this is a REAL problem or just people not used to the feel of these EPS and not 'feeling' the steering as its so different than your traditional hydraulic steerings....Hope its not a flaw in their design but as Colin said....they have been doing ESP in some cars so I doubt that they haven't properly developed these before implementation...
nice
joflewbyu2
10-08-2015 11:16 AM
