Dashboard lit up like a xmas tree
Was in the car for about 15 minutes this am. I stopped for gas and when I started up almost all of my dash lights popped on. Excluding battery and engine lights. Car seems to be running fine, battery is only 2 months old and alternator was tested.
light that are on are
ABS
VSA
BRAKE
I shut it off and restarted but no change. Thank you in advance
chris
ABS
VSA
BRAKE
chris
Model and year of car?
I had the ABS go out in my Silverado. Happens all of a sudden. Chevy told me it was $1500 repair so I just pulled the fuse, which disabled the cruise control as well. A year later I found https://modulemaster.com/rebuilds/
Cdin88 (01-29-2020)
Per the TS guide:
VSA indicator comes on when VSA is lost.
Brake System indicator comes on when the EBD Electronic Brake Distribution function is lost, parking brake applied, or fluid level low
The Diagnostic Code should be stored, but may need a special reader, not normal OBDII. The Honda Diagnostics System is suggested.
With ABS, Brake and VSA on: check for DTC codes, the troubleshoot based on table...... (guess you need the HDS reader to go here.)
