Check engine code! P2422
Driving in to work earlier this week my check engine light came on. I checked the code and it is P2422 (Evap canister vent shut valve close malfunction).
After some research, I found that there is a service bulletin on this (08-052).
With 67,000 miles on the car, would this be covered for repair under the TSB? Is there a warranty/mileage restriction on TSBs? Is it dealer discretion?
I'm going to call and ask the dealer later today, but I figured I'd throw this out to all of you first and see what everyone thinks. Thanks in advance.
WARRANTY CLAIM INFORMATION
In warranty: The normal warranty applies.
Operation Number: 1200A1
Flat Rate Time: 0.3 hour
Failed Part: P/N 17743-TA0-A01
Defect Code: 05401
Symptom Code: 03203
Template ID: 08-052B
Skill Level: Repair Technician
Out of warranty: Any repair performed after warranty
expiration may be eligible for goodwill consideration by
the District Parts and Service Manager or your Zone
Office. You must request consideration, and get a
decision, before starting work.
Defect Code: 05401
Symptom Code: 03203
damaged442 (09-12-2012)
So it looks to be a 15-20 minute job plus the part. Since the TSB mentions out of warranty, it sounds like there is a good chance of getting this covered but you must request the goodwill repair and get approval prior to the dealer starting work.
Billu99tl
09-13-2015 11:30 AM
HeloDown
09-08-2015 06:51 PM
