Cannot Set Clock
Cannot Set Clock
After daylight savings, I found myself unable to set my clock 1 hour ahead in my 2010 TSX. No errors. Just won't save the time change after I change it using the menu. I know older Honda units are having issues as of the new year. I believe they need some firmware updates from the manufacturers for Honda. Anyone have an idea what might be going on?
Thanks!
Martin
Thanks!
Martin
Similar problem. My clock somehow became unset a month or two ago - about 59 minutes fast. Daylight time made it just one minute off. I have tech package on 2009 TSX so clock is supposed to get correct time from satellite and none of the setup controls have any impact. Satellite signal is working as I can get the preview channel, but doesn't set time. This problem started after I cancelled Navtraffic and had a battery issue that needed after jumpstart required me to enter the navigation security code (but not the radio code).
Any idea of the fix??
Hey I actually might be useful here for once. It's a known problem. the clocks reset to 2002 in January because the satellites or whatever cant handle 2022 so no matter what you do the clocks wont set. It's (supposed) to be fixed around august when they auto update. the "fix" for it is disconnecting your battery or pulling your radio fuse and reconnecting it at 1PM
There's 4 Acuras on my block. I own 2 of them 3/4 of them had the clocks mess up
Theres actually a site for it
https://didhondafixtheclocks.com/
mshipon (04-17-2022)
BigBluu
01-11-2005 01:18 PM
