Blinking D and check transmission
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
I was wondering if anyone can help. My CHECK TRANSMISSION light came on and the green D is blinking. I turned off the car and started again there is no blinking D and no check transmission code. I though it might be transmission fluid change time (175,000KM) I got the fluid from Honda dealership and change it through local garage. and then again light came after 3-4 months,whenever I turn off the engin and start again there is no light and everything goes fine. I took it to my mechanic, he said he couldn't find any codes indicating a problem.
-Checked transmission oil, its good and correct amount
-Do change my car oil every 7000 km
-checked with OBD everything is fine no codes or anything
-Car running fine in auto and sports mode
-TSX 2009 Tech pack 190000KM
Wondering if there is sensor or anything saying good bye or have to replace !!
Anyone else have this problem? I have no clue, hopefully someone on here can offer some suggestions. Thanks!
It's likely an intermittent circuit fault on some trans electrical component. Nothing to do but get the code w/o turning engine off when it appears. Shop can't fix what they can't see.
good luck
good luck
