Aftermarket Brakes and Rotors
I am new to buying aftermarket items for my car so I am looking for help finding brakes and rotors for my 09 TSX.
At about 8200 miles on my TSX my brakes were making a rubbing noise and sqeaking on braking constantly. I take the car to the dealer and he tells me all my brakes and rotors were completely shot. Now they replaced them all free of charge and told me I must have been breaking to hard. Now I dont know much about this but I'm pretty damn sure I dont break hard enough to kill all my pads and rotors at 8200 miles.
I've gone through all the posts on here and seen a ton of brake problems so I basically decided to just get non OEM brakes. Thanks for any help!
WTH happened to my garage
I have 20 k miles on my 09 TSX & I've already had all four rotors cut by the dealer at less than 10k miles. I had to stop short at a traffic signal on a 55 mph road yesterday and now they are warped very badly.
*Someone* needs to check fitment of TL/TL-S hand-me-down Brembo's for our cars.
You can visit our forum's vendors websites and look under the 1G TSX. Waiting on mine to wear out so I can get some new brake pads and rotors.
Yeah, right? After unknowingly doing R&D for Brembo on the 99-00 Civic Si GT kit from them, I'm not in a big hurry to be the first kid on the block.
As for the 04-08 tsx brakes being the same. I do know that Acura has different parts for the model years. They might be the same size and fit but Acura didn't use any of the old TSX brake parts on the 09 TSX. They all are different part numbers. Also next week my car will be at Brembo so I will find out if they have a kit pretty soon. My guess it that the old TSX kit will fit alreadly or with very little mods to it.
Little side note. Acura didn't change anything on the brakes for the V6 model.
I may be spoiled, my other car has Brembo's F&R, but in the TSX I don't late brake, ride the pedal, autocross or anything. Usually I putt around like a Grandmother & my brakes are obviously undersized for the I4!
I was just thinking yesterday about buying OE or good aftermarket rotors and sending them to OneCryo (CryoOne, whatever)
Former Sponsor
A link to which part? You can just go under an 04 TSX and purchase rotors/pads under that. Check out the ROTORA rotors and H2 ceramic brake pads. For the BBK look under STOPTECH BBK's and just reference in the comments you want a 09 TSX kit so I can have the correct lines sent.
STOPTECH has already confirmed fitment.
http://www.hondanews.com/categories/740/releases/5040
They state there is an upgraded braking system. Since rotors diameters seem unchanged, this would lead me to suggest they have reformulated the pads.
This is incorrect.
If that's the case, I would think maybe this might be a 1/2 step upgrade for the I4.
I agree, it could mean anything, but it does not mean "nothing" as BOOSTED09TSX posted. Opinion vs. fact is important.
This is incorrect.
All that I checked was the brake pad and rotor part numbers. Both the V6 model and I4 use the same numbers. I just assumed that the cailpers would be the same. I will check when I get back to work on Monday. I should have looked at all the numbers before saying there was no difference.
wow this is messed up. now im scared to brake hard lol. i used to destroy the brakes on my rsx and the rotors were perfect. i changed the pads 4 times but the rotors never warped. i guess its the extra 700 lbs. gayy.
I finished checking the part numbers for the front and rear rotors, pads, calipers, lines. They are all the same. I did find that the brake master cylinder is different and of course Acura said the directed more air flow towards the front rotors for cooling.
With that said I dont think that just changing the master cylinder is going to make that big of difference between the two braking systems as they stated. With the same brake lines I wouldn`t think the the extra pressure would help that much. Than again I am not a engineer just a lowly parts guy
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
08_UA7_Gr33k
09-27-2015 01:56 PM
