2nd gen TSX captures Speed Touring Car Championship
I haven't been following this series since the Realtime Acura team was racing 1st gens but from the looks of things the 2nd gens are doing very nicely:
http://www.world-challenge.com/news/story.php?ID=1495
I wonder what kind of mods they're running...
yeah i heard about this earlier. awesome!!
heres the mods to the first gen tsx:
Chassis
2750 lbs minimum weight (with driver)
Steel Unibody with RTR prep and chromoly cage
RTR Carbon-Kevlar Spoiler
RTR Carbon Splitter/Undertray and Rear Wing
RTR Carbon Center Console
RTR Carbon-Kevlar Hood and Trunk
EFI Data Logger and Dash Display
Hella Switches and Relays
Racetech Communications radios
Sparco seats, belts and steering wheel
AP Racing Pedal Assembly
AP Racing Air-Jacks
TOTAL Autobody paint work
Optima Battery
Suspension
Front double wishbone / Rear 5-Link
RTR chromoly tubular Front Upper/Lower A-arms
RTR chromoly tubular Rear Links
RTR Rear Upright with Spherical Bearing Inserts
Moton triple adjustable shocks
Eibach springs
RTR Front anti-roll bar
RTR MOMBO™ rear anti-roll bar and mount
Brembo four-piston monoblock front calipers
Brembo two-piston rear calipers
RTR Brake Ducts
Hawk Performance brake pads
Enkei Competition wheels
Series-mandated Toyo Proxes RA1 rubber 235/40/17
Drivetrain
K24A2 block and head
RTR baffled oil pan
RTR cams
CP 12.5:1 compression pistons
Eibach valve springs
Carillo Rods
RTR spring retainers
RTR Engine Mounts
EFI engine management
RTR header and exhaust
C&R Racing radiator
RTR Carbon Radiator Shroud
RTR Airbox
RTR Spec ASU5 6 speed gearbox
Red Line Oil engine/trans lubricants
BOSCH spark plugs and fuel pumps
Goodridge hoses, lines and fittings
Tilton Flywheel and Clutch
Fuel Safe Fuel Cell
Chassis
AP Racing Air-Jacks
Optima Battery
Suspension
Eibach springs
RTR Brake Ducts
Drivetrain
RTR baffled oil pan
RTR cams
Carillo Rods
RTR Engine Mounts
C&R Racing radiator
RTR Airbox
Fuel Safe Fuel Cell
