2nd gen better bolt on perf?
yes
2nd gen - 3400-3700lbs. the heftier version is probably from the V6 engine.
at the lightest, the 1st gen TSX is 3200lbs and bolts ons didnt make the car any quicker.
bolt ons for the 2nd gen will result in worse results because of the heftier car.
They both have k24's with about 200 crank HP.
the weight in the 2nd gen WILL hinder performance. Unless you go for the bigger v6 engine
to clarify; only the 6MT was the fun one...because you can choose your own shifts and the tranny only weighed like 200lbs as opposed to the auto tranny that weighs like 400-600lbs
if you are looking for a fun car; the 1st gen 6MT with bolt ons would be it.
Y'all need to eat your wheaties.
The manual trans weighs like?? maybe 80-100LB.
Auto probably 120-150ish.
The K24A2 in the 1st gen also reacted really well to bolt ons and tuning. Then again...maybe I'm thinking of Michael Bolton and Crooning?
An intake and reflash on the K24A2 makes like 30whp in the midrange, IIRC.
There are like 280ish WHP K24A2's out there with ZERO aftermarket engine components (with bolt ons and ECU tuning).
I don't think the 2G responds nearly as well.
Stock A2's put down 170ish HP through the 6MT and 160ish thru the slushbox. The 06-08 A2's are also a bit under rated....and are graded at "205hp" on the newer SAE scale.
9000revs (11-15-2017)
COT dang my biceps are accurate as scales.
http://www.superstreetonline.com/how-to/transmission-drivetrain/1306-honda-engine-drivetrain-weights/
http://forums.clubrsx.com/showthread.php?t=730211
They have had the N22 with 6MT in the Accord for a while, but of course not in this market. The new variant was hitting 76 mpg. I could do a wagon with 60+ mpg and a manual trans.
