AcuraZine - Acura Enthusiast Community (https://acurazine.com/forums/)
-   2G TSX (2009-2014) (https://acurazine.com/forums/2g-tsx-2009-2014-143/)
-   -   2G TSX Key Fob Alternative? (https://acurazine.com/forums/2g-tsx-2009-2014-143/2g-tsx-key-fob-alternative-972117/)
Shiba Aug 3, 2018 01:36 AM
I was looking at replacing one of the switchblade type of key fobs with a Honda style key found online. It looks slightly less bulky with less moving parts to fail. Has anyone tried this? Looking at the photos it looks like there is a spot for the transponder chip and I haven't found anything yet to make me think this wouldn't work.
Keyecu Remote Car Key 313.8MHz ID46 Chip Fob for Honda Accord 2003-2007
https://cimg2.ibsrv.net/gimg/acurazi...203dd62088.jpg
knavekid Aug 4, 2018 09:24 AM
The immobilizer transponder chip should be included with the key and will need to be programmed into your ECU. A good automotive locksmith and program it for you. The correct FOB electronics is important and must match the TSX operation. I needed a second FOB and after several aftermarket FOBs would not sync as "Driver 1", the locksmith procured an OEM FOB. There is a difference in the electronics for the Driver 1 and Driver 2 FOBs, so if a different Honda FOB works, you might lose the ability to sync the driver settings with the FOB.
Visit a local automotive locksmith and they may be able to offer you an alternative to the switchblade FOB.
© 2026 MH Sub I, LLC dba Internet Brands
