2010 tsx window weather stripping
What specifically do I need to replace these in all of my windows. The original weather stripping is cracking and is all sticky. Is it hard to do?
https://cimg4.ibsrv.net/gimg/acurazi...885582bea.jpeg https://cimg8.ibsrv.net/gimg/acurazi...5f966a354.jpeg https://cimg5.ibsrv.net/gimg/acurazi...e6321859b.jpeg https://cimg9.ibsrv.net/gimg/acurazi...e3ca337a5.jpeg https://cimg2.ibsrv.net/gimg/acurazi...c8b479e88.jpeg |
see link. for search "auto window weatherstrip" good luck |
Every vehicle I've owned has been basically the same. Roll the window down, grab the trim, and pull up. There are a few clips that hold it in place.
Look at the new part you're replacing the old one with to see where the clip points are since that's where the resistance will be, and then yank there. Pop the new one in and yerdun. If you put a warm beer in the freezer before you walk out to do it, it'll still be warm when you go back after wrapping up. It almost takes longer to roll the windows down as it does to replace the trim. |
https://www.hondaacuraonline.com/oem...iABEgLOmvD_BwE
Is this the part? Looks like it's just the rubber piece and not the actual trim? |
Originally Posted by rawger
(Post 16461182)
Originally Posted by cu2wagon
(Post 16461323)
I think the part you posted is the inner trim piece; he needs the one on the outside of the door.
Window weather strip
Does anyone have a link for the window weather stripping? I need to do mine on my 2010 TSX
I have the same issue on my 2011 tsx.
My wife drives a 2010 TSX and her windows weather stripping needs to be replaced. Do you need to remove the side view mirrors to replace the front door weather stripping?
| All times are GMT -5. The time now is 08:41 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
