2009 TSX Dashboard removal and radar hardwire help
I have a 2009 tsx, and i guess it's because it's a fairly new car, i can't find anywhere on how to remove my dashboard so i can hardwire install my passport 8500 radar detector. the cord is a direct-wire smart cord, so it has the mute box attached and i have to go underneath my dash to make it clean and hide it well....any help?
So you are so impatient that you needed to post a new thread 4 minutes after you posted this? That thread has been deleted.
Someone will be along shortly to answer your questions, or you could search for the answer. I'm sure someone has already asked and received replies.
And welcome to the forums.
I hardwired my Cobra to the sunroof which took only 15 mins max. Basically, you pry out the light covers, take out the bulbs, unscrew two screws, pull the whole assembly out, feed the wire through, find a ground (there are bolts in there), use a T-tap to connect the sunroof. As for the dashboard, I don't know
WTH happened to my garage
This is a forum, consider it a savings account. You contribute where you can, and in a sense, that allows you to make a withdrawal by drawing on other's experiences when needed.
No contribution/participation and a withdrawal slip in hand, insufficient funds.
Regress to cussing out those who effectively *own* the *private* site & your account will be closed.
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
