19 inch HFP wheels question !?
Hey everyone I can get a good deal for some Honda hfp 19 inch wheels I was just wondering what is the recommended tire size to prevent rubbing and if I ever want to lower it in the future...they will replace the 18s on my v6 ... Thanks !!!
https://cimg8.ibsrv.net/gimg/acurazi...dfcb6fe84.jpeg |
Use a tire/rim calculator. Either way, you won't rub with these because of the oem offset.
This should help
https://acurazine.com/forums/tires-w...s-pics-893883/ |
Originally Posted by Rdub81
(Post 15691242)
This should help
Originally Posted by max4swag
(Post 15691253)
Thanks thats exactly what I was looking for ... Is the v6 lower then the 4cyl model ?! If yes I might need a little less drop to compensate ?
(Post 15691253)
Originally Posted by VR1
(Post 15691444)
don't think hes active on here, but @melo_cu2 on IG has H&R springs with those wheels on his 2.4 and no rubbing.
(Post 15691444)
(Post 15691563)
Thanks... I've been reading a lot about these wheels on this forum and some talk about spacers .. What does this mean ?
(Post 15691863)
Only thing i was thinking is are Spacers necessary for this setup ? 245/40/19 tires and H&R springs 1.25 all around !!
Originally Posted by ulrblitzer
(Post 15691921)
Owners add in spacers between the rim and hub to be flush or clear fitment issues (alter offset of the rim). In this case, its probably to have a more flush look (push rim out towards fender).
(Post 15692071)
No, the spacers are not necessary to run those wheels. You can add spacers if you want to make them flush if they aren't already.
(Post 15691187)
We're all 5x114.3 regardless of I4 or V6. You'll be fine.
C'mon Max4! Quit asking questions and get it done...
I want to see these on your car! :D |
Btw, what kind of deal are you getting on these wheels?
Originally Posted by cu2wagon
(Post 15693411)
Originally Posted by Username 0
(Post 15693533)
(Post 15693829)
800$ Canadian with 245/40/19 Yokohama tires about 50% thread left ..they are used but in excellent condition no curb rash a couple of very minor nicks from rocks that I consider normal .. Overall there in excellent condition
Thats a steal. i would jump on that in a heartbeat. Im in toronto too, did you find those on kijiji or elsewhere? |
Originally Posted by D4nnyD
(Post 15694605)
