100watts for DRL?
100watts for DRL?
i just ordered some nokya 7000k bullbs for drl but didint notice that it was the stage 2 model which is 100watts compared to stage 1's 65watts. should i contact the ebay member to help me switch it or is 100watts fine for the 09 tsx?
WTH happened to my garage
Do not use higher wattage bulbs than what the assembly calls for. At best it will melt the wiring at the harness, at worst, it will melt the headlamp assembly socket receiver where the bulb goes in or cause a short in the system.
Can't wait to drive
Never put anything higher wattage than spec'ed, you will melt your housing away. Try to return the bulbs. If you really want to go brighter, you can do a HID conversion, but you'll have to pull your DRL fuse for that to work.
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
