Will RDX Wheels Fit TLS?
Item Specifics - Auto Parts: Wheels
Rim Material: Alloy Bolt Pattern: 5 x 4.50 or 5 x 114.3
Rim Width: 7.5J Rim Brand: --
Rim Diameter (inches): 18 Rim Structure: One Piece
Offset: 45 Manufacturer Part Number: --
Number of Bolts: 5
Just Need a Final Answer IF they will FIT MY 03 TLS
This is happening for sure. i have my mind SET to buy the RDX Wheels. Now the only thing im looking at is if i can Fit 225/45/18 instead of 225/40/18 .
I have Koni Yellows with Tein S-TEch, 2.1 From Front and 1.6 Drop from back. Im guessing its less drop than that because of the Konis. my Drop didnt go that low so its less than 2.1 and 1.6.
The other reason is the Koni Yellows are too stiff already. Even with the settings i have on them for NY. thats y i need a little more rubber.
Give me some Good Advise Experts!
So i finish with this MOD quick and get on with performance mods.
you sure you want to buy another oem rim which you already have an oem rim...I still take the oem type S over these rims...Id go buy a set of after market rims instead...pluse buying a set of brand new oem rims is pricey...unless you find used ones on ebay or something..just my
I'd rather be driving:
Originally Posted by spoonspec
you sure you want to buy another oem rim which you already have an oem rim...I still take the oem type S over these rims...Id go buy a set of after market rims instead...pluse buying a set of brand new oem rims is pricey...unless you find used ones on ebay or something..just my ![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
The Rim looks Nice. I like to keep my car Stock but Better Looking. Atleast to compete with those Newer Model Cars these days. The reason im not getting after market is my simple reason to keep my car look stock but beautiful. This Gives the Car a Newer Model Look. Instead of a custom look. In my opinion, i Like the Cars better the REAL way.
Its a different story when it comes to Performance though
Anyways, im Getting those RDX18ns tonight and will post the pictures Once they are on my car!
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
what's the center bore on the hub of that rim??
nanos
11-12-2015 08:41 PM
