wheel spacers
3 pedals in my 99 TL
you could run spacers. id do 25mm if you got tsx wheels if your trying to sit more flush with the fenders if thats what you mean by aggressive. are you lowered? cause if you arent it wouldnt look right if you put spacers on. i have the same wheels and was thinking of running 25mm spacers but im slammed so id definitely have to roll my fenders and cut tabs for it to fit. hope that helps.
Yea that actually helps alot bro should i do 25 on the front and back or what setup should i run and yes i am lowered with tein spring s. I cut them alittle in the front to look a li lowel. Also what spacer should i get and how much do they run for
jmoney2001
09-11-2015 12:07 PM
mtl_ilx
09-03-2015 09:48 AM
