wheel fitting is the hardest.... another question
Agean Blue Bishes
1 Post
18x8 with a 45 offset. i think this would work since 18x8 with a 48 offset would.
could i go with 235's or would i have to have 225's?
dropped on pro kit
i have never been so confused with wheels before. some say it rubs and some say it doesn't. so idk what the hecks going on most the time.
any one running a set up like this at all?
dropped on pro kit
Dragging knees in
That setup will extend the wheel 29mm further than the OEM wheels.
Will it work? Well, yeah. But you will have to cut the tabs and roll the fenders.
FYI, my set up extends 26mm than OEM and the wheels sit just about perfectly snug with the fenders. At 29mm, do it at your own risk.
As for the tires, 235/40/18 would be the ideal setup to match the diameter of the factory tires so the speedometer/odometer isn't off much... but that will rub like a son of a bitch. Go with 225/40/18... it will make it a tiny bit better.
But then again... I would recommend going with a narrower wheel or a higher offset. You're going to rub and you're going to hate it. Trust me, I'm speaking from experience.
Agean Blue Bishes
1 Post
yea i fuggin hate finding rims for this car.
i wish ron would make something like the hiros in the right fitament.
i found a set of 18x8 hiros for 750 bucks and i saw them listed for 280 a wheel.
the search continues.
thanks for the help
thanks for the help
