Vehicle "leans" to left
After a buddy of mine pointed it out, it is apparent that my car sits slightly lower on the left side than on the right. I slid my fingers between the tires and wheel well and noticed that there is indeed a slight difference. What would/could be causing this?
Can you give us some more info? Is it running on stock suspension, lowered?
Could be a bad shock, or a sagging spring.
While it's quite possible to have a blown shock....ya may want to closely check the other suspension components on that side. Could possibly be a control arm or maybe even the sway bar linkage ?
Look things over and compare both sides. Push down on the affected rear side and see if it's noticeably different or softer than the other. Also check for signs of fluid seeping from the shock.
99Ackrite
Hey all, my accord does this too. Just on the rear left. Done it with the stock suspension and also with my kyb's and lowering springs?????? Nothing is bent, alignment is perfect, and rides great. If you guys know what to do or try let me know.
rockyboy
01-25-2016 06:00 PM
