tire size help needed
looking to put
FALKEN ZIEX ZE-512 B
235/45ZR-17 97W REIN
on a 2003 TL-S as replacement for the OEM with the bubbles....
will these fit ok or should i seek something else? Any suggestions would be appreciated.
99 TLS6 08 TL
tires
You should probably go with a P225/50ZR17. I think that will be a better fitment. Try looking at www.discounttire.com or www.tirerack.com. Either of those sites should help you out. It's up to you though. A 235/45ZR17 will more than likely fit also. If you're having issues with bubbles, a smaller sidewall is not a good idea IMHO.
If you have TL-S rims (6.5") -- the 235/45/17 tire won't fit (well, not recommended -- they need at least 7.5" rims). I don't know if any tire installer would put those tires on TL-S rims. Try another size or get another set of wider rims.
cammy5
09-04-2015 11:26 PM
nuldabz
09-03-2015 05:49 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
