Tire size?
in general on the TL when one is lowering it -
225 will clear in the rear without issue- any wider and you have to cut the fender tabs---run your hand along the fender edge and the issue will become clear...
caution for bleeding!!!!!!!
ask a tire shop what will fit on your rims- at a certain point its just too wide for the rim
and no amount of trying will even get them on~
B A N N E D
now 225 all the way around would proably not be too much a problem though, they are only 10mm oversized then stock width
and yes keep the same size all the way around the car, then you can at least rotate them, and help even out the wear on them
I need 2 more gears
225/55/16's will work fine and they look a lot better IMO than the skinny 205's a TL-P comes stock with. I know TL-S come stock with I believe 215/50/17's I believe so not sure if you'd want to go 225/50/17 or 225/45/17. Probably 225/45/17 to keep the rolling diameter close to the same. You don't want a speedo that's not reading right.
Agree. Do not slap on a 245 tire on factory rims. Rim is not wide enough to safely install a 245 width tire.
Moved to appropriate forum.
Lamborghini Aventador FTW
nuldabz
09-03-2015 05:49 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
