Suspension Help!
Suspension Help!
So I have a Acura TL-S 2002 and I just got some H&R racing springs. I'm about to put them on this weekend with my buddy, do you guys recommend getting struts or just putting them on my oem struts?
If so, which struts do you recommend?
Also pros and cons of getting new struts?
Thanks!
Thanks!
YES, Get New shocks. Especially if yours are original. I recommend searching the forum a little in the (Tires, Wheels,Suspension) Area (where the thread was moved to) There are many good options, just depends on what you want to spend. I personally recommend Koni or Bilstien, but there are other less expensive alternatives.
USE POWER TOOLS! this will help out incredibly and save you tons of time. you can do it with hand tools but you will be sore. I just installed springs on mine. it's an easy task. you should install new shocks with it to save the hassle but if you dont mind doing it again, go for it.
MrHeeltoe
20
02-23-2023 01:54 PM
lanechanger
10-13-2015 10:56 AM
MrHeeltoe
09-29-2015 10:43 PM
adreano17
09-29-2015 08:48 AM
MrHeeltoe
09-28-2015 05:43 PM
