Stock Tires Size Offset ??
Offset Question
If I stick with the stock wheel and tire sizes, do I need to be concerned with the offset distance? If so, what am I looking for? Will 35-40 mm work? Thanks.
I have Toyo Proxi TPT, 205/60/16 with the factory 16 x 7 rim. The tires have only 5k miles on them and I just want a new wheel for them. All the 16 x 7 wheels I am looking at have an offset between 35-45 mm. Will this cause any problems.
Ackniculous One
Originally Posted by jayhawk815
First off, I believe the factory wheel is 6.5 inches. If you're going to go through the hassle and spend money on new tires, why not get something larger? If your new tires are your concern, I'd just wait till you need new ones.
Why?? Why do I need bigger tires and wheels? I know everyone does it but, why? Looks? Performance? Before I think about bigger, tell me why.
Ok. If I go bigger. What do I need to look for in order to get the proper fit and not effect the speed?
Thanks for all the help!!!
Here is a link that explains it pretty well.
http://www.tirerack.com/tires/tirete...al/plusone.jsp
I know the offset on my 2000 TL is +55. My question is, how little of offset can I get away with. Seems it is very difficult to find 16" wheels with offset higher than +45. Will +40-45 cause any problems? Thanks.
BTW....Going with a bigger wheel is not an option. I want to stick with the 205/60/16.
Looking at Tirerack and Tires.com, they all recommend 16 x 7 wheels with offsets from +38 and up. Are they wrong?
if you are spending the money why not atleast plus size 1 or 2? the over all cost isnt going to be much if any of a difference.
+38 is way to low. i personaly wouldnt drop below a +47 no matter what size i was running
I am looking at some 17" and 18" packages on ebay. Are BSA and Ikon good brands? I have been able to find some offsets on BSA and they offer +45. I have not been able to find any on the Ikon wheels. Does any one know anything about these?
DunesCreations
09-09-2015 12:03 PM
nuldabz
09-03-2015 05:49 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
