Slight rub?
Slight rub?
Maybe someone can shed a bit more light into what's causing some rubbing on my rear tires. Here's some basic info:
Slightly tucking tire (maybe .5 - 1" tucked)
Bumper tab cut
Fender not rolled (but there's is quite a bit of clearance.. but really close to where the bumper connects)
Running 225/40/18
18 x 7.5 +42
Is it just rubbing against my fender liner? or something else? Just curious to what it might be, I'll prob raise it just a bit so it's barely tucking at all. Only happens on slopes, driveways, etc (which is probably the obvious reason, just trying to double check..) Wonder if other people get slight rubbing as well who are tucking..
Thanks.
Bumper tab cut
Running 225/40/18
18 x 7.5 +42
Thanks.
Semi-fixed lol
i. shaved a bit more off my bumper and..
ii. raised it a tad
Still get some rubbing on harsher angles, but it's riding a lot better. Will look more into it in spring. Don't know how some of you guys do it lol
ii. raised it a tad
So I was searching around and found one of your other posts where you posted this up:
![](https://i42.photobucket.com/albums/e312/JjAshAa/IMG_7281.jpg)
..same thing with mine. Did you every touch it up with rust spray or anytning like that? It's crazy how canned you can get on F2's! lol
Haha that's awesome.. I don't get why I rub much more with this car cause I've driven dumped on my other cars with barley any scratches. Maybe the car is longer, wider/bigger tires.. meh- lol
emailnatec
29
09-28-2018 04:27 PM
