Shocks/Springs or Coilovers? $8-900 budget
Hey guys! Long time no see!
My struts wore out and was wondering if I should go shocks/springs (thinking Koni/HR Race) or instead (was thinking F&F type II or TIENS BASIC) and just install it myself.
Another problem is that I can't find any DIYs for the coilovers =/
I have an approx. $8-900 budget. Plus I have 18" rims so I am worried about rubbing if it goes too low. This is for a DD 2000 TL and I am looking to buy by no later than Friday so I need your help guys!
Lemme know!
Lemme know!
Rice Patrol
^this.
I have the koni/HR combo and while i love it over stock, it is an absolute pain in the ass and with coils you could always redo your height whenever you want
i would agree on getting coilovers with your budget..but shock/springs are only a pain in the ass if you don't know what your doing..
Received 1,080 Likes
And most importantly, whatever you buy, make sure it is from one of our sponsors.
https://acurazine.com/forums/sponsored-sales-group-buys-10/
well i dunno what your trying to do but if you wanna improve handling you should Soften front dampers or stiffen rear dampers (since this is a FWD). Also install wider tires at the front and narrower at the rear. Anything else you will hurt the handling. also consider the following:
More negative front camber
More positive rear camber
Softer front springs
Stiffer rear springs
Thinner (weaker) front sway bar
Thicker (stronger) rear sway bar
Weight distribuation more rearward
All this information was taken from Neuspeed.
after considering these then pick the brands you like from the parts, there are lots of good ones.
Tires, all the same size, front dampener was set stiffer than rear, Rebound was also set higher in the front than rear, front camber was set less than the rear, (i had 1/4 toe out set to the front) front spring rates pre determined by H&R and cant control that, front sway larger than oem, rear larger than oem, weight dist is about the only thing i agree with.
If you took that info and applied it to the TL you would wrap your car around a telephone pole the first time you went around a corner
K. Just bought the Form & Function Type II Coilovers for $899 + FREE Shipping (and warranty/returns) from VEX Motorsports.com since I couldn't find a better price on the forums. Thank you all for your help! I have 18's on the car so it wont go that low. Still deciding whether to go soft or firm after being so used to stock.
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
If i were you i would mod it to get the same performance as a CL-S. CL-S does 68 MPH slalom opposed to 62 MPH for stock TL. Again softer front is the key. Just look at why cars are really good at handling for example the NSX has Front springs 3.0 kg/mm stiffness / Rears 4.0 kg/mm.
read on a Sport Compact Car Magazine once about a family sedan (i think it was 2000-2001 Corolla) fitted with TRD suspensions. it managed to pull 70mph at the slalom! thats crazy compared to it's 57 mph stock.
"The stock NSX has a rear bias in its spring rates, where the rear springs are stiffer than the front. On hard deceleration upon corner entry, the softer front springs allow weight transfer to the front wheels, increasing front grip and thus improving steering response. However, the weight transfer also takes weight off of the rear wheels, causing them to lose grip. The net result is a tendency toward oversteer,"
Rice Patrol
I know to all the more experienced people its not hard...but to people who aren't as mechanically inclined (read: me.) it was very annoying.
I'd say the worst part was the non-adjustability of it. Once it was seated, I wanted it slightly (read: slightly) lower in the front. I couldn't change it. If I had gone with the coilover route, I could have.
Overall I'm happy, but I still think coils are an overall better option. Unless of course you're low on funds and are going the OE strut/Lower Spring method
Koni SP3. Adjustable has 5 spring perches to allow the perfect height.
Rice Patrol
^I knew that but I wasn't sure if I could do it without having to take the entire unit out again...
If it is just taking the tire out, then please explain what I need to do! (remember, I'm new to this...) I'd have to be really motivated to remove everything and take the strut/spring unit out again
No you need to remove the shock and take the load off the spring with spring compressors. Did you ever adjust the rebound on the shock before you installed them (only way to adjust it)
Rice Patrol
ahh ok yeah I figured as much.
yeah I did some googling and set them in the beginning, I just picked the middle setting.
Thanks for the info, I'll have to do this when I have a free afternoon.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
4drviper
09-23-2015 07:42 PM
