Rotors freezing on the spindle what's the best cure?
I have a 2001 TL and recently replaced the rotors with some Duralast (Autozone) rotors. I am also currently replacing my struts and upper control arms. While doing so I wanted to re-check the rotors to see how they were doing and they were rusted to the spindle and it took me about an hour of tapping on them to get them off. Is there any good rust prohibitor that will handle the high temperature and not come off on the rotor surface? Any suggestions?
I use anti-seize....below is the product description...never had a problem taking any rotor off that I applied anti-seize on...notice the text that are highlighted in blue...and don't let the food in the name fool you, they recently changed the name...it is great on cars....you can get the regular anti-seize, but this one is like it was designed to keep the rotor from sticking to the hub being that it is for high heat applications
HI-TEMP FOOD GRADE™
Anti-Seize Compound
(Formerly High-Temp Pure White™)
Hi-Temp Food Grade is a heavy-duty assembly paste designed for high-temperature applications in the Food/Beverage and Drug/Cosmetic industries.
Hi-Temp Food Grade is formulated to meet FDA and USDA requirements where incidental contact with food can occur. It adheres to metal surfaces and has anti-rust and anti-corrosion properties vital to protect equipment from harmful attack of corrosive acids found in food substances.
Features and Benefits:
• Effective at temperatures to 2100ºF (1148ºC)
• Pure, tasteless, non-toxic, and non-staining
• USDA H-1 and FDA approved
• May be used with potable water
• High solid content for long life
• Excellent resistance to wash out
Applications: All Metal-to-Metal Surfaces where disassembly is a requirement after exposure to High Temperatures, Corrosive Conditions, or Harsh Environments.
HI-TEMP FOOD GRADE™
Anti-Seize Compound
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
