Question about alignment and camber kit
Ok, here is the problem: I lowered my car with Tein Basics in the summer and I found out today that my 2 front tires are worn (almost bald) on the toe (inner tread), the middle and out tread has tons of meat left. I got my car raised today about 1.5-2" up from before in the front. I got my winter tires installed today and I dont want my winter tires to suffer the same consequences as my summer tires did from inner treadwear, should I go for an alignment and get camber kits even when I raised the car up about an inch or two? Or should I just leave it cuz I raised my car and Im not gonna have inner tread wear problems?
Thanks!
Thanks!
ANY time you mess with the suspension you SHOULD get an alignment PERIOD. You shouldnt need a camber kit, especially up front. Get an alignment and if the specs are out of range after that THEN get a camber kit. Then when you lower it in the spring Get another alignment and do the same. Yes its a pain but if your going to be raising and lowering the car its a must. Just because it drives normal doesnt mean that the alignment is fine. Look at your wear, most likely a consequence of toe.
I will get the alignment done next week, i'll also post the spec for you to see as well.
Zonian22
11-14-2015 01:20 PM
nuldabz
09-03-2015 05:49 PM
Zonian22
09-02-2015 08:19 AM
