Project kics wheel spacers???
Scooby doobie crusin
gunna be on my prokit and tokicos pretty soon, if i like the way the wheels look ill probably keep em but i dont like how are back wheel tucks in a bit i was thinkin about throwin the project kics wheel spacer just in the rear... you think i can pull off a 15mm?
Lamborghini Aventador FTW
I have the same suspension as you, and I have CL-S wheels with 225/50/17 tires. I put 10mm spacers and there was no rubbing when no one was in the back seat. The second even one person sat in the back, there was rubbing. I also have my tabs cut. It could be because my tire is taller than stock by about 1 cm. I know it's not a lot taller, but I think its just a few mm that is causing my rubbing.
Of course, you can run more negative camber to make it fit better, but you may have uneven tire wear.
EvilVirus
12-10-2015 07:38 PM
jmoney2001
09-11-2015 12:07 PM
