Next suspension
Old 04-15-2009, 11:46 AM
  #41
Avant Garde Wheels
jjashaa's Avatar
Originally Posted by jjf
ok if I go the full route say with the teins@$1500 including the lowering springs. plus a rear sway bar the next question becomes do I need to roll the rear fenders to deal with a set of
TENZO TYPE-M VERSION 1 BLACK, RED STRIPE with 18X8 inch tires?
which teins? if you're going coilovers like Tein SS or Tein Basics, which those are coilovers not shock/springs, then you won't need springs. they come with spring mated to a shock body with adjustable height and dampening control(only for Tein SS).
if you are wondering about wheels and rubbing... that is a whole new thread...
first, we have to kno how much your dropped.. what wheels, and size(18x8) and offset (+55.. +40.. +32... +47.. etc etc etc)
and then WE can help you from there as to if you'll rub or not and what tire size we would recommend you to get.
Old 04-17-2009, 08:06 AM
  #42
remikinz's Avatar
Originally Posted by Anotherguy831
I went with KYB AGX (8-way adjustable shocks) with H&R springs; nice drop and if you set the shocks at the highest dampening... your riding on rails but not for daily use. Right now Im driving them on teh 2nd setting around town and max setting when I decide its time for a nightly cruise. But my set up cost somewhere around 900. Coils where a good idea but in chicago the salt and debris gets into the grooves and you cant adjust them so i decided to just go with the shocks
Got the same exact set up. Right now Im on 2 in the front and 3 in the back nice and smooth ride and on the highest settings these shocks are stiff! Not back breaking stiff but definently stiff lol when I first had everything changed I had them set at the stiffest setting and was bouncing around the car lol
Old 04-17-2009, 08:07 AM
  #43
remikinz's Avatar
handling is nice and tight too and I dont have any sway bars... yet
Old 04-17-2009, 08:49 AM
  #44
jjf
jjf's Avatar
This gets me started in the right direction. as for the tires and wheel offset I will get back
once I get all the info. I blew it on the current set of rims because I did not check the offset so when I have folks in the back and hit a bump they rub. I did cut the tabs which helped yet it was not enough.
MrHeeltoe
20
02-23-2023 01:54 PM
lanechanger
10-13-2015 10:56 AM
MrHeeltoe
09-29-2015 10:43 PM
adreano17
09-29-2015 08:48 AM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: Next suspension
