Need urgent help!
Need urgent help!
Folks,
I just got the eibach pro spring kit with the damper kit installed on 2003 acura type s. A proper alignment was done was well..however the drop in the back looks more lower than in the front.
The picture is below. Apologies for crappy cell phone quality, but just concerned here. I just got them installed today..
Am i going crazy or...anyone else have these on ran into the same issue.
I would appreciate all comments and advise please.
heres what i would try
jack up the whole front.. and loosen the bolts that hold the suspension assembly in place.. mainly the lower fork bolt that connects to the arm and the top 5 nuts
once that is done... assuming you have your floor jack..
use that to put load onto the suspension while the car is in the air.. then tighten all the bottom components.. lower the car and tighten the top 5 nuts
